Sponsored by: CARiD
air pump
Old Aug 16, 2002 | 08:05 PM
aerodogg's Avatar
air pump
I took out my air pump. What should I bypass if anything. And any other parts I should take out.
Old Aug 19, 2002 | 10:43 PM
Use a block off plate,many sell them or you can make your own. You will need to take the pressure sensor line that went to the air pump and "T" it in will the return line off the BOV(blow off valve). Don't forget the pill in the pressure sensor line.Just bend in the line to you find it, it is usually about 3'' down from the air pump side of the line.You need it for boost issues.Cap off the 3 remaining lines and make sure you have no leaks.....
Hope that helps...Search around to make sure you know what you need to do. Ask a few people!!!!
Benny
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
Frisky Arab
Sep 4, 2015 06:17 PM
rotor_veux
Sep 3, 2015 07:10 PM
