Engine undershield..off/on...
Old Aug 15, 2002 | 08:23 PM
T2 Tsunami's Avatar
Stud Service
I was wondering if this cover is important and why...I have been trying to change the radiator fluid and I could'nt get to the drain plug so I took it off. By the way,has anybody drained their fluid lately?, the only drain plug I found down there looked like it was on the oil cooler and I could'nt budge that one.
Old Aug 15, 2002 | 08:33 PM
banzaitoyota's Avatar
What Subscription?
The cover is IMPORTANT to maintain the correct flow of air thru the radiator.
Old Aug 15, 2002 | 08:39 PM
T2 Tsunami's Avatar
Stud Service
Am I looking at the right bolt to drain the radiator fluid?..the only one I seen was a large bolt on the oil cooler. Thanx
Old Aug 15, 2002 | 08:49 PM
I wish I was driving!
It is a plastic phillips head (+) screw in the middle of the bottom of the radiator, and a bolt in by the motor mount on the driver's side motor mount to drain the coolant.
Old Aug 15, 2002 | 08:52 PM
T2 Tsunami's Avatar
Stud Service
Thanx alot..have to check that out in the morning.
Old Aug 15, 2002 | 10:15 PM
Josepi's Avatar
Despise Enmity
Agreed, be sure to put it back on after you drain.
Old Aug 15, 2002 | 10:36 PM
Wankel7's Avatar
Haven't we ALL heard this
Make sure you drain the block of coolant also for a complete job
James
Microtech
30
Apr 23, 2016 06:37 PM
Wicked93gs
Aug 23, 2015 10:14 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
