compression results
Old Aug 14, 2002 | 04:39 PM
rxspeed87's Avatar
compression results
well I just did the compression test on my car
on the rear rotor I was pulling 95-105 psi on all 3 (couldn't tell for sure the exact number) think it was more around 100 though
and on the front rotor I was pulling around 105-115 (again couldn't tell for sure but I think it was around 105
what is the stock compression arting on the s4 N/A?
Old Aug 14, 2002 | 04:48 PM
SonicRaT's Avatar
Super Raterhater
should be around 120 new, and around 100-120 in normal use, and 80-95 when it needs to be rebuilt
Old Aug 14, 2002 | 05:00 PM
rxspeed87's Avatar
so how much life do you think I have
the car already has 176k on it?
Old Aug 14, 2002 | 05:08 PM
SonicRaT's Avatar
Super Raterhater
change all her fluids and spark plugs, filter, etc and it should last for quite some time still.
Old Aug 14, 2002 | 05:12 PM
rxspeed87's Avatar
think I have a chance of hitting 250k?
why is it also that the rear rotor always seems to be lower then the front?
oh the test was done with both leading plugs out and the car at WOT
that is the right way to test it correct?
Old Aug 14, 2002 | 06:49 PM
Roy James's Avatar
My cars louder than yours
Yeah man, seems like you are doing a great job of maintence on the car. IM sure you can probably reach 250K if you continue with whatever you're doing. IM not sure about the rear one being lower than the back, but my theory is, which might be wrong, is that the pressure comeing from the OMP is greater in the front bc it has less distance to travel than in the rear and it gets more lubrication. Again, this is just a theory i pulled out my ***, no accual evidence to back it up. Other than that, i have no clue. Anyone?
Old Aug 14, 2002 | 06:55 PM
Rotorific's Avatar
I dont know a damn thing
If its that good or norm for 176k you have a good chance to hit 200 but set your goal for 225k around the 180 to 200k mark is when engines go but it depends on the maintenance
Old Aug 14, 2002 | 07:00 PM
niner's Avatar
an engine builder told me that he thought the reason why the rear rotor is usually the one that goes first is mainly due to the balance of the engine
Old Aug 14, 2002 | 08:20 PM
rxseven's Avatar
Special Dark
The 13B in my GSL-SE has 180K miles and has identical compression numbers as yours. Still pulls great but I am starting to get a little too much fuel dilution in the oil. Be weary of that, if it stays around the full mark all the time, you will need to replace the oil monthly. Oh and using a little premix won't hurt either. I use 1/2 oz/gallon.
The rear rotor goes out first cause the rear part of the eshaft sees the most amount of flex.
turbodreamz22
28
Nov 10, 2023 11:08 AM
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
userjh5174
Alternative Fuels
Jan 9, 2016 08:49 AM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
