RB springs and tire rubbing
Old Aug 14, 2002 | 03:50 PM
CYM TKT's Avatar
hey, your car is on fire!
ok guys, after some research I decided I want to get the RB springs. what I could not find though, is whether my 245/45 tires on stock wheels will rub or not. I have a 93 R1.
Old Aug 14, 2002 | 10:22 PM
ARD T2's Avatar
They won't rub in the rear. In the front it's possible under hard cornering. Really depends on where the compression dampening is set on your shocks.
Rishie
Old Aug 17, 2002 | 10:28 AM
Ned M's Avatar
I have the same setup and tire size, with R-1 shocks. I have had minimal rubbing of the tire in the front fenderwell liner on track under bigtime compression; never on the street.
Old Aug 17, 2002 | 10:51 AM
yy4u's Avatar
I'll second what Ned had to say, some rubbing up front under hard breaking and hard cornering at the same time, no problems otherwise
Old Aug 17, 2002 | 02:35 PM
mako's Avatar
i run h&r springs on stock toruing shocks. i just put 245/45/16 on the front last week and i am getting a lot of rubbing on only the drivers side of the car. even just low speed turns its rubbing?
I am pretty sure its has put a hole in the fender liner by this time as well..
any ideas. i think my shocks are tired as well.
thanks,
James
Old Aug 18, 2002 | 12:15 PM
SleepR1's Avatar
No rubbing with H&R Sport Springs and stock Showa R1 shocks. You can experience them for yourself. See my sig
Old Aug 19, 2002 | 11:27 AM
rynberg's Avatar
You're selling the FD, Manny? Why? Are you getting another one or moving on?
Old Aug 19, 2002 | 12:39 PM
SleepR1's Avatar
Moving on, see PM
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
