can a bad Turbo timer cause you car not to start correctly?
Old Aug 12, 2002 | 10:56 PM
For about 2 weeks now I've been having trouble starting my 90 TII. I can't figure it out and niether can Mazda. They checked just about everything. Here are my observations during start up: Sometimes you need to try to start it more than ounce, Need to push gas pedal, feels like it needs gas, Sputters for a few seconds and then idles correctly, mostly happens when engine is cold. Tonight when I started it I obsreved the turbo timer starting its countdown. Could the timer be bad and causing a problem with my ignition? Could it just be a loose connection? Could it be a bad ignition?
Old Aug 12, 2002 | 11:02 PM
TheBigOne's Avatar
Disconnect the TT. Do you have a power button for the TT? Turn it off. See what happens. R U sure your not flooding out?
Old Aug 12, 2002 | 11:15 PM
Positve I'm not flooding! I have a power button. What should I expect to see besides my car run? Or should I turn it off before I start it?
Kyo
Apr 13, 2019 09:24 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
gtcd
30
Aug 19, 2015 02:44 AM
