0-0-11 boost pattern... (no primary)
Old Aug 12, 2002 | 04:59 AM
az_lynx's Avatar
Ok... I know about there having to be 8psi for the secondary to come on... so there must be pressure in the pressure tank... but on my gauge there is 0psi on primary turbo and around 4500 the secondary comes alive and strong as usual.
I would go nonseq but I like the feeling of the seq turbos.
A little background... I just got done doing a full hose job... replacing gaskets and cleaning stuff up.
I'm wondering what EXACTLY I should look for or test?
Old Aug 12, 2002 | 05:39 AM
Rated R1's Avatar
Oji San
http://home.iSTAR.ca/~dvandit/turbocharger.htm
This is an excellent site to troubleshoot your turbochargers.
Old Aug 12, 2002 | 07:20 AM
Wade's Avatar
I had this problem before. There was a kink in the hose going to the Charge Control valve. So it would stay open before 4500 RPM when it should be closed (and boost would leak out of the Charge Relief Valve, then at 4500 RPM the CRV would close and all hell would break loose.
Check your Charge Control Valve and the hoses related to it.
Wade
Old Aug 12, 2002 | 10:15 AM
az_lynx's Avatar
Thanks but checked there already... not a single thing relating to my problem
Originally posted by Dont_Be_A_Rikki
Since you replaced all the hoses. Was it like that before the job? If it was o.k before then you got something all messed up.
-Rikki
p.s. or it is a shot primary turbo.
I kinda figured that much
I know what it is..... you don't want to help because I'm denying the nonseq!!!! I see how it is!!!!
Wade
Thanks Wade!..... I can only hope it's somthing that easy! I will check it when I get home.... I'll also check and see maybe the CRV is just sticking open in general.
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
Bauer778
Nov 4, 2015 04:42 PM
connerfd3s
Sep 19, 2015 05:58 PM
