anyone ever do a front differential mount?
its a pain in the ***. you have to drop the subframe to do it. as far as i know mazda is the only one who makes it, they have 2 though. the competition and the stock one.
mike
mike
apparently on one of the sights I checked out, Energy suspensions polyurethane kit comes with that bushing. I needed to know if the sub frame did need to be dropped. How much of a pain in the *** is it? Ive already done a complete front end swap and a clutch in my driveway.
Trending Topics
Well, then here's the advice.
Drop the subframe.
100000% times easier.
Can you do it without that? Sure, loosen the subframe nuts, remove the drivers side nut, and lower so you can get your tools up there.
Easier to drop the subframe, that way everything's out in the open.
Do you need more advice? How to drop subframe? Not sure how familar you are with this stuff.
PaulC
Drop the subframe.
PaulC
ok i can give y ou a jist of the write up right here:
disconnect your rear brake lines, remove your rear swaybar, there are 2 mounts up above the rear axle, 2 mounts in front of the rear tires and some other odds and ends stuff.
make sure the car is up high and supported well. if you really need more of a description drop me a PM and i can walk you thru it.
Its not a pain in the *** like everyone makes it sound. Its just time consuming. I lowered the subframe a bit and removed my exhaust from the "Y" pipe back. You dont have to remove the exhaust but you have more room to work with without it.
Heres a good thread about it:
https://www.rx7club.com/forum/showth...threadid=39026
Read through it and youll get lots of good info.
What are the symptoms of a broken diff. mount. When I start to move in my 86 base model I feel this shuddering coming from the rear end. Only happens after the car moves about 10 - 15 feet. Is that a broken mount?
James
James
i did it the other day and i had to drop the subframe, i just let it hang on top of the exhaust. (not the best idea in the world), i just disconnected the camber link and the shocks and the main bolts. changing your differential is a BIG PITA
good luck
Justin
good luck
Justin
