just installed Greddy SMIC & Elbow no 2nd turbo
Old Aug 9, 2002 | 05:24 PM
books's Avatar
I just installed a Greddy SMIC & Elbow and now the no 2nd turbo does not kick in, does anyone have any idea of what I may have done during installation to cause this...
thanks Dave
Old Aug 9, 2002 | 08:23 PM
Lunar7's Avatar
Do you have a boost guage?
How much boost are you getting?
Did you plug the line that was removed from your stock elbow?
Old Aug 9, 2002 | 08:42 PM
books's Avatar
yes I have a boost guage and yes I plugged the line that went into the original elbow
the boost was reading around 10.5 until around 4500 rpms when the 2nd turbo is supposed to kick in
after 4500 it decreases toward zero
I checked the charge relief valve and the hose is connected
by the way what is connected to the other end of the hose that was in the elbow? bypass valve??
Old Aug 9, 2002 | 09:02 PM
duboisr's Avatar
it is the sorce of air for the cold start 3000rpm plug it or put a block off plate at the other end to rid your self of the ugly hose and plug
Old Aug 10, 2002 | 04:43 PM
books's Avatar
thanks guys...the problem's fixed...the cap I put on the hose was loose and sucking air
rotor_veux
46
Jun 12, 2018 10:39 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
