Cleaning radiator / condenser fins
Old Aug 5, 2002 | 04:30 PM
80-CU.IN.T's Avatar
What chemicals can be used to clean an air conditioning condenser or radiator?
The condenser has road tar, paint over spray, ect. on it. How can I clean in between the fins? Hopefully there is a miracle chemical for cleaning aluminum. If necessary the condenser can be dipped.
"ANY ADVICE WOULD BE GREATLY APPRECIATED"
Old Aug 5, 2002 | 04:44 PM
KINETIK_FD3S's Avatar
almost done
not sure but you can try degreeser.
Old Aug 5, 2002 | 07:27 PM
80-CU.IN.T's Avatar
I High pressure steamed it and that helped. High air pressure can bend the fins. I was hoping to find a chemical cleaner for aluminum. Does anyone know of one?
Old Aug 5, 2002 | 09:34 PM
duboisr's Avatar
Carb cleaner from Auto Zone in the yellow can is cheap and works well then wash with water if you are thinking the cleaner will harm the aluminum . Why over kill with some hard to find costly chemical . the carb cleaner will remove dirt, oil grease paint, the water will remove the cleaner easy fix.
Old Aug 6, 2002 | 12:09 AM
80-CU.IN.T's Avatar
Thanks for all the responses.
I talked with a friend and he has a light acid solution and neutralizer that he said he works great. No label. I will try it on some 6061 -T6 and some and other various types of aluminum that I have lying around. If it isn't too corrosive I will use it. He said it will make my condenser look like new again.
