Just picked up a T2 parts car!!! Anyone need any parts?
Old Aug 3, 2002 | 08:25 PM
boostmotorsport's Avatar
Its a 87 T2 with 90K and a perfectly good stock running motor!!! Get this 375$!!!!!!!! Roof is smashed( why its a parts car), and he is a good friend. I am keeping the motor to rebuild(1st time), polish, port, and build with a TO4, Haltech etc etc. But there are many other parts I dont need. What do you guys need?
Old Aug 3, 2002 | 08:28 PM
Roy James's Avatar
My cars louder than yours
You got a brake vac source check valve? i think thats all i need for now. Thanks
Old Aug 3, 2002 | 08:32 PM
hypntyz7's Avatar
I can use the wiring harness and injectors, and boost sensor. Also the air flow meter. Let me know what you might want for each part, and then for it all. I really need that wiring hanress, everything else is just so I can have spares.
Old Aug 3, 2002 | 08:57 PM
I can get you the injectors, and AFM, and harness minus the last 2 inches to the water pump temp post, and alternator plug. make me some offers, I hate this process!
Old Aug 3, 2002 | 09:00 PM
hypntyz7's Avatar
So the harness is damaged? What part exactly is not there? My harne3ss is ok, but Im chasing an intermittent problem that was today cured by an NA harness temporarily, so IM looking for aknown good harness, not just something to slap on there. I'd give $150 for it all, provided the harness is what I want.
Old Aug 3, 2002 | 09:24 PM
niner's Avatar
i'm lookin for ecu maybe, and possibly other stuff
i'll post back by tomorrow evening for sure
Old Aug 3, 2002 | 10:07 PM
Pinfield357's Avatar
im looking for a CPU not the ECU. i need the ont he drivers side near the fuse box let me know if you can part with it thanx man
Old Aug 3, 2002 | 10:37 PM
how much for the whole drivetrain?
Old Aug 3, 2002 | 10:46 PM
I cut off the harness the plug at the back of the altenator, and the plug off the temp sensor on the thermostat housing. Other than that the harness is oily but fine. Just splice in those 2 parts and it is mint. As i said the motor is stock so there has been no F'ing with it. I would take 150$ for the harness, injectors, and MAF. The injectors have no cracks in them, as my(other T2) original secondaries did. I own a speedshop so if you are willing to make a check or $ order out to it and send it over I will mail you the parts. Let me know what you think, I am flexible on a payment plan, but quite archaic when it comes to modern payment options(paypaletc). I could also take a credit/debit card # over the phone. Call me(Fred) at my shop(Boost) Mon.-Sat 11:30-6:00 EST and we can work out a plan. Also I know the MAF is good cuz he had a mixture issue and replaced the MAF recently and it cured the prob.
And as for the CPU I have that-make an offer.
Old Aug 3, 2002 | 10:48 PM
AS for the drivetrain, the tranny is crap with mostly bad synchroes, and the diffy is my new backup. Sorry
Old Aug 3, 2002 | 11:47 PM
SwooshMand's Avatar
Do you have the power window switch from the drivers side? and how much for it and the harness.
Old Aug 4, 2002 | 12:42 AM
RexRyder's Avatar
window switch fer passenger?
Old Aug 4, 2002 | 02:06 AM
Roy James's Avatar
um.. what about that check valve?
Old Aug 4, 2002 | 02:34 AM
AreExSeven's Avatar
Huh?
Is the interior still in OK shape? What color is it?
Old Aug 4, 2002 | 02:56 AM
Liquid Anarchy's Avatar
We come with the Hardcore
Keep the Tail-lights... you need em' :-D Just messing with you.
If you're going to get a bigger turbo, haltec, etc. Then you don't need those pesky 550cc injectors... do ya?
Old Aug 4, 2002 | 03:59 AM
TurboII RudeBoy's Avatar
Post count is over rated
i want the behind the dash harness
Old Aug 4, 2002 | 08:20 AM
chris1234p's Avatar
Ill give you $5.00 for the radiator air bleeder cap. Please email me at chris1234p@hotmail.com if this is possible.
Old Aug 4, 2002 | 08:30 AM
ColumbusTurboTwo's Avatar
bleh its worth a try.
is the sunroof intact? even tho the roof is smashed?
Old Aug 7, 2002 | 11:05 PM
SwooshMand's Avatar
i need the drivers side switch if you have it.
Old Aug 7, 2002 | 11:17 PM
Kaneto's Avatar
Hmm, how about all hubs and brakes at all four corners? I want to swap my 4-lugs out for 5.
Old Aug 7, 2002 | 11:33 PM
mazdamanda's Avatar
Moderatorator
I need a BOV kit and starter if you have it. Let me know.
Thanks,
Amanda
Old Aug 8, 2002 | 12:47 AM
hypntyz7's Avatar
On second thought might oughtta be careful what we buy...we might get a box with "HONDA MOTOR COMPANY" parts inside...
cam_7779
Aug 18, 2015 07:48 AM
baconflavored
SE RX-7 Forum
Aug 12, 2015 12:07 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
