help over heating problem
Old Aug 3, 2002 | 04:06 AM
purestud81's Avatar
i have a 88 gxl with an aftermarket turbo and a bunch of other mods to make more power but now my car over heats like crazy. i have a stock brass radiator, and a very powerfull electric fan with a 180 stat. what could i do to cool it down without sacrificing performance?
Old Aug 3, 2002 | 06:18 AM
banzaitoyota's Avatar
What Subscription?
Switch to EVANS NPG+. www.evanscooling.com
Old Aug 3, 2002 | 08:49 AM
deadRX7Conv's Avatar
Opinions are like........
Get a real radiator. What 180 stat? Just use the Mazda one and replace the cap while you're at it.
Make sure all shrouds are in place.
Stock radiator is good for stock power output.
Overheats per dash gauge??? or overheats by blowing/boiling the coolant out??
Old Aug 13, 2002 | 09:03 PM
purestud81's Avatar
i have a 3.8 turbo buick engine in my car putting out 650 hp to the wheels. when i had the conversion done i thought the radiator would work but it doesn't. would an aluminum radiator help? i have aftermarket gauges and my temp reaches 250 degrees.
Old Aug 13, 2002 | 09:32 PM
pip's Avatar
pip
the blackest incarnation
Of course another fc in wisconsin, but someone put the wrong motor in it =/
Old Aug 13, 2002 | 10:02 PM
650hp, what the f^&k are they putting in that Wisconsin drinking water? The stock radiator could just about keep the 160hp rotary cool.
You need bigazz radiator with a gargantuan fan. Good luck. Must be hell of an adrenalin rush to drive that thing.
Heres a thread concerning radiator size and fitment:
https://www.rx7club.com/forum/showth...threadid=99657
And for the fan, either use a dual 12" setup or go for a single 16"-18" electric if it fits.
Old Aug 14, 2002 | 01:26 PM
purestud81's Avatar
thanks man the thing is i hardly have any room left to put a huge radiator in. but i allready have a big *** electric fan i think an aluminum radiator should help
Old Aug 14, 2002 | 02:47 PM
Aaron Cake's Avatar
Engine, Not Motor
The electric fan will make your car run hotter.
You need to upgrade to a better rad. Fluidyne makes a unit that is only very slightly larger than stock, but is vasty superior in cooling capacity.
Old Aug 14, 2002 | 05:28 PM
Thats stupid. Tell that to the owners of millions of vehicles that have electric fans.
Heres another stupid quote, "The mechanical fan will make your car run hotter".
See, whats it missing. PROOF!
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
