Offset [FC]
Old Aug 2, 2002 | 05:00 PM
Offset [FC]
Yes, I've done searches but I haven't found anything that gives me a definitive answer.
I'm considering either 16x7 or 16x8 inch wheels for my 1988 GTU. I know if I stick with 16x7 and 205/55-16s I can run the stock offset no problem. What I'm wondering is if I should go up to a 225/50-16, and if so, if I should go to a 16x8 and what offset I'd need to run.
Old Aug 3, 2002 | 12:00 AM
ARD T2's Avatar
Is your car lowered? I'd run a 225/45/16 up front if you can find that size and a 225/50 in the rear. That's if you're lowered.
You'll want around a +35 offset on a 8" width. Maybe a tad bit higher. I'll check on monday or something. I have some FD wheels with that size I can fit onto my FC and see what kind of backspacing we're looking at.
Rishie
Old Aug 3, 2002 | 05:53 AM
Turbonut's Avatar
With the stock 16" wheel, which is 40mm offset, you can barely use 222x50's (Only in certain makes). If you go to an 8" with a 35mm offset you'll be moving the wheel @ 1/2" closer to the strut...No Good without a spacer. To keep the same distance from the strut you'll need a 27mm offset. Depending what type/size tire you're going to use, you could go a few mm more.
I'd stick with 7" and go wider in rear.
This calculator will help.
http://toy4two.home.mindspring.com/offset.html
By the way 1 mm = .03937 inches
Old Aug 4, 2002 | 07:30 PM
Not lowered yet but it will be. I have a deal right now where I'll be getting some wheels for free - if that happens there'll be no worries cause the style I'm looking at is a 16x7, and from what I understand I shouldn't go above a 205mm section width on that rim size?
If the deal falls through I'll be looking to buy some wheels and in that case I've got other choices. It's a 50/50 thing right now but I want to be prepared.
Thanks!
Old Aug 5, 2002 | 04:33 AM
ARD T2's Avatar
When the offset is higher that means the wheel is pushed in more. The lower the offset the farther out it will be.
I've run +40, +37, +35, and +31 offsets on 8" width. I'd reccommend a 225/45 up front.
Rishie
doritoloco
Sep 17, 2015 03:51 PM
