Sponsored by: CARiD
Need Tech help pls!!!
Old Aug 1, 2002 | 10:48 PM
rx350's Avatar
Question Need Tech help pls!!!
Working on breathing life into a recently purchased "dead" rx7 (1986 gxl...13B)
Managed to get it to fire up, and run....it hits 2000 rpm, then dies....
Is this a fuel pump problem....I dont hear the fuel pump charge up when I turn the ignition on...but when I turn the motor over it pumps....
I also tried plumbing a bottle of gas into the intake, the engine will hapily run (with very poor throttle response...of course) until the gas runs out...
am I correct in my fuel pump assumption??
Old Aug 2, 2002 | 01:19 AM
duboisr's Avatar
see if the air flow meter is opening or not , the fuel pump is good idea also, disconnect the inlet line ,put it in a jug and prime with the yellow connector jumper wire trick to test the pump ,no fires now good luck
Old Aug 2, 2002 | 09:45 PM
Piranha's Avatar
what 7
look for vacuum leaks.. these cars will die pretty easy with them.
Sh00bs
Oct 1, 2015 11:57 PM
Postman09
Sep 29, 2015 11:23 AM
