Incorrect Fuel Gauge Readings!
Old Aug 1, 2002 | 08:56 PM
silverrotor's Avatar
I've noticed that my FC consistantly displays Incorrect readings. When I fill up, like to the neck of the fuel tank opening, my gauge reads 3/4 full! But when I'm low on gas my gas light and readings are correct. What gives? Is the float in the gas tank suspect?
Everything works on my 88 GXL. No rattles, electrical bugs or rust. It bothers me that the readings are out of whack! What could be causing this?
Old Aug 2, 2002 | 05:20 PM
Come on, nobody. I'm sure somebody knows.
Old Aug 2, 2002 | 05:31 PM
HAILERS's Avatar
HAILERS
Just a bad sending unit in the tank. Been there, done that. Wreck yard . The online manual gives you some values to check but its most likely the float unit in the tank. Pumps attached to the same structure. Mine would show three quarter at full and after maybe a hundred miles drop to zip. Swapped with my other car and all was well. Went junk yard. Maybe ten bucks wo the pump.
Old Aug 2, 2002 | 05:56 PM
So If I get one from the dealership, what do I ask for? Fuel float sending unit? Also the FSM makes no reference, let alone a picture, to the sending unit
Old Aug 2, 2002 | 06:05 PM
jmseven's Avatar
Asset is Wealth
You will need the sending unit assy. Mazdatrix has new assy for $72.
Snoopy FD
Dec 8, 2015 01:45 PM
sYnth.
Aug 19, 2015 06:27 PM
