Public Service Bulletin
Old Aug 1, 2002 | 06:10 PM
ZeroBanger's Avatar
I hope I am not intruding....but my 2 cents to add would be
1) upper radiator hose. Remove the Airbox and inspect. if you see buldges around where it attaches to the radiator, replace it.
2) Coolant overflow container. These go bad alot, they get small cracks that expand when hot and leaks coolant, when cool does not leak. The symptoms are...You park and about 1 to 2 mintues later it drains a big puddle under the car. You fill it up and it its not leaking anymore. next time you drive and park it leaks again.
Old Aug 1, 2002 | 06:21 PM
kmaot's Avatar
I know, not original BUT sometimes worth repeating..
Oh Rikki you're so fine, you're so fine you blow my mind...
Old Aug 1, 2002 | 06:38 PM
legendr35's Avatar
It's probably a good idea to use Evan NGP+ coolant also.
Old Aug 2, 2002 | 05:17 AM
jspecracer7's Avatar
1JZ powered
...AND get an aftermarket radiator already!
On a side note...I watched my water temps closely today...and was surprised at lunch time to see my PFC water temp was at 79 Celsius! I have my fans turning on at 80 Celsius so
Then I realized that my A/C was on...and I don't have A/C...
Old Aug 2, 2002 | 09:57 AM
pomanferrari's Avatar
A public service from non-partisan supporter of PFS:
9) replace both turbo coolant lines, which require removal of airpump;
10) replace heater hose in front of the engine engine; heater hoses into and out of firewall on both passenger and driver's side;
11) replace hose under the TB;
12) alternative method of burping system: make sure car is cold; jack car up in the front, stick a large mouth funnel in the fill hole, pour in coolant so that it goes up the mouth of the funnel; start engine, wear gloves and watch air bleed up through the funnel as engine comes up to temp. Shut off and replace cap.
Old Aug 2, 2002 | 09:58 AM
EDIT first line: non-partisan NON-supporter of PFS.
Old Aug 2, 2002 | 11:27 AM
JspecFD's Avatar
Don't forget changing the thermostat
Old Aug 2, 2002 | 01:42 PM
turbojeff's Avatar
Do it right, do it once
Yeah out of all these tips, only one guy got one of the most important parts that is failure prone.
Check/change your T-stat. The stock temp gauge sucks so bad that your engine can be mildly overheated and the guage still reads normal.
I've seen several FDs with t-stats that only open partially. This allows enough coolant through to keep the engine at normal temps while cruising but will lead to overheating in traffic and spirited driving.
I've had enough FDs to see this happen more than once.
Jeff
Old Aug 2, 2002 | 04:24 PM
Fd3BOOST's Avatar
Recovering Milkaholic
If only I had followed these guildlines sooner!! Arghhh!
Oh well I guess i'll be learning how to rebuild and port like I always wanted.
Old Aug 2, 2002 | 07:08 PM
Rx7pimpin's Avatar
Has anyone ever run their FD without a Thermostat?
I know what the response will be, but I have heard of people in piston engines doing this to help with cooling problems.
Old Jun 21, 2003 | 03:54 AM
SaulV's Avatar
OG
First and for most. Thanks Rikki, Excellent thread! I think my problem is thermostat and those lines mentined here
[/B][/QUOTE]Can someone post pictures or give more details to track these hoses.
11) replace hose under the TB;????? which are these? whats tB?
Old Jun 21, 2003 | 08:17 AM
RonKMiller's Avatar
Blow up or win
Good advice, but looking for bulges really won't tell you much about the condition of your hoses. The best method (actually the only method) is:
1) Squeeze the hose near the clamps or
connectors when the engine is cool.
2) Use fingers and thumb to check for weakness, not the whole hand.
3) Squeeze near the connectors. The interior hose "rot" occurs within two inches of the ends of the hose -- not in the middle.
4) Check for any difference in the feel between the middle and ends of the hose. "Gaps," or "channels," can be felt along the length of the hose where it has been weakened.
5) If the ends are soft and feel mushy, chances are, the hose is toast. Replace that sonamabeach immediately
or you'll be walkin' home.
This procedure has been brought to you as a NON-PROFIT (sorry Ricki, I just could not resist...) public service message by a guy who likes to help his fellow rotary lunatics do it right the first time.
Old Jun 21, 2003 | 08:52 AM
Herblenny's Avatar
DGRR 2017 4/26-4/30, 2017
Originally posted by muzik3k
replace hose under the TB;????? which are these? whats tB?[/COLOR]
actually this happened to me and I changed it out..
Its the coolant line from the pump to the TB.. apprently it supposed to cool or warm the TB... Completely useless if you live in non extreme weather condition area... Like AL.. My line used to leak and didnt know where it was coming from.. SPOautos looked at and told me about it.. simple fix..
Old Jun 21, 2003 | 09:06 AM
RonKMiller's Avatar
Blow up or win
First off, what is a "piston" engine?
Sure, it will help with cooling problems, but you still have not figured out what the problem is.
It's shade tree mechanic philosophy at it's finest.
When starting, you want your engine (and especially your oil) to reach operating temperature as quickly as possible to minimize wear and maximize performance, and that's exactly what a thermostat does.
Without a thermostat it would probably take your engine 20 minutes to warm up instead of just a couple.
That's alot of metal grinding away.......
Old Jun 21, 2003 | 10:35 AM
SaulV's Avatar
OG
[/B][/QUOTE]WHICH HOSES ARE THESE?? HOW CAN I FIND THEM, PICTURES PLEASE??
Old Jun 21, 2003 | 10:59 AM
artguy's Avatar
WTB** Very Low Miles 94-95
remove the black foam rubber lining from the rear of the engine bay...im talking about the strip near the windshield wipers...it unclips easily....relocate your ast toward the front and do as much as you can to create breathing room in there...run an aftermarket radiator, airbox, intercooler and DOWNPIPE...
if you got the cash....get the power fc and datalogit...simply reset when all your fans come on so they come on earlier and stronger...my temps are down five degrees celcius from that alone.
get a water temp guage...that stock guage is ***! if your car goes over 100c...pull over and let her cool down....keep an eye on your temps like you would your speedo if a cop was around.
the main reason people lose their motors to o ring or side seal failure is because they do not monitor their water temps. I check my temps every single time Im in the car and check them often. been there done that.
good luck
j
Old Jun 21, 2003 | 11:24 AM
Wargasm's Avatar
Weird Cat Man
Jeff
Whenever I have the thermostat out or even if I have a NEW ONE, I heat it up slowly in a pan of water on the stove with a thermometer in it to see exactly when it opens up and how much it opens up to make sure it looks like it's working.
It only takes 15 minutes and it will help make sure your brand new TStat isn't a motor-killing dud.
Brian
Old Jun 21, 2003 | 11:58 AM
jdhuegel1's Avatar
Glug Glug Glug Burp
Brian
VERY good advice.
Old Jun 21, 2003 | 02:03 PM
wonder1and's Avatar
I Sold My Car 2 the Devil
On the thermostat... should I get a pettit one or a mazda stock one and drill a hole in it? I was dumb and replaced mine with an autozone one and found later that people have tested the so called 180deg thermostat and it didn't open till 200deg F ... suggestions? I'm going to probably remix my coolant and and some water wetter... (I live in hell aka Texas)
What do you people think about the TB coolant Bypass? I was thinking about doing it but wasn't sure if it would make a difference.
TIA,
Ryker
