Does the pilot bearing need lubed?
Old Aug 1, 2002 | 12:49 PM
az_lynx's Avatar
Hey.... I have my motor all back together and am installing the new lightweight flywell and ATC S/S Clutch tonight then putting the tranny back on.... I got the old pilot bearing out and put the new one in and a new seal. Do I need to lube it up or do I just put on the new flywheel and clutch and put the tranny on there?
Anything I should know? (yes... this is the first time I've ever done this )
Thanks,
Chris
Old Aug 1, 2002 | 01:13 PM
j9fd3s's Avatar
Community Builder
yes put grease on the bearing. also make sure that the throwout bearing slides easily, and all the obvious moving points are greased
mike
Old Aug 1, 2002 | 01:23 PM
az_lynx's Avatar
mike
Ok so this might be a stuipd question.... but umm.... what kind of grease? I mean... I have used WD-40 to lube stuff but I'm guessing that as in grease... I need somthing different? I guess I could prob go to checker and they would get me somthing....
sorry for the stuipd questions... but ya gotta learn somehow
Thanks
Chris...
Old Aug 1, 2002 | 01:41 PM
Turbonut's Avatar
No, don't use WD40 that will wash out brg. Use a heavier consitency eg wheel brg. grease. The grease should be "kneeded" into the bearing. Place grease into the bearing, exert pressure onto grease to push into little needle brgs, and remove excess. As stated above lube where fork rides on throw out brg and also front of trans where throw out brg would slide...A small amount.
Old Aug 1, 2002 | 02:29 PM
Freaky Monkey007's Avatar
If you have a grease gun that would work great for this. For bearings( i could be wrong) i heard it was better to use lithium grease. Please correct me if im wrong though.
Old Aug 1, 2002 | 02:53 PM
Red Rotary Rocket's Avatar
If I recall correctly, the shop manual calls for molybdenum sulfide based grease for the pilot bearing. Don't quote me on that though...best to check the manual. I seem to recall that it does in fact specify what type of grease to use.
Old Aug 1, 2002 | 03:21 PM
j9fd3s's Avatar
Community Builder
you want something thick, like wheel bearing grease. just go and buy a tub, it works well for hinges and stuff
mike
Old Jun 19, 2008 | 11:47 AM
Newbie
You are correct. Page J55 of the workshop manual specifically states to use molydbenum grease.
I found this thread on a different forum about greases:
http://www.tundrasolutions.com/forum...bdenum-grease/
Old Jun 19, 2008 | 01:10 PM
DaleClark's Avatar
RX-7 Bad Ass
I've always used wheel bearing grease with no problems. Get a small wad on the end of your pinky, shove it in there, and work it into the bearing.
The shop manual shows the spots on the throwout bearing fork that needs to be lubed - the two "ears" of the fork, and also the part of the tranny the throwout bearing rides on. All with wheel bearing grease. Make sure those parts are clean and dry, then apply the grease. The TO bearing grease points don't need a lot, just a little more than a thin coat.
Dale
Old Jun 19, 2008 | 02:57 PM
Tom93R1's Avatar
gross polluter
Hopefully after 6 years this wasnt still an issue
Old Jun 19, 2008 | 10:10 PM
grimple1's Avatar
Turd Ferguson
oh it is... it is.....
Vartok
16
Oct 8, 2015 04:49 PM
Devon Murray
Sep 25, 2015 09:41 AM
