<< Please advice >> - Yet another query on boost problems.
Old Aug 1, 2002 | 01:04 AM
Question << Please advice >> - Yet another query on boost problems.
Here is the scenario:
- No boost on neutral on WOT (I understand it should be somewhere near 4 PSI).
- 6 PSI max on any gear on WOT, with no apparent transition between turbos.
- All the major boost hoses were verified ok.
- Tested car with no actuator hoses and there was no boost increase.
The car is a stock 93 RX7.
Any help will be appreciated. I'll hate to sell the damn car without testing it to its full potential!!
Old Aug 1, 2002 | 08:16 PM
How can I increase the boost on the primary turbo without adding any other hardware? Is there any valve or rod that I could adjust on the turbos?
Old Aug 1, 2002 | 08:35 PM
legendr35's Avatar
i had this problem, my intercooler piping had a leak, I would check the lower intercooler elbow, make sure its not loose.
Old Aug 1, 2002 | 08:37 PM
toecutter's Avatar
I had the same problem.
I also tried to fix it by replacing my pills with valves.
Finally I replaced the hoses and cant believe I waited so long 10-7-10.
I could probably adjust the vales and improve a bit
but Im just enjoying the way it drives compared to before.
Just replace the hoses you wont regret it.
Old Aug 3, 2002 | 12:07 PM
Any other suggestion will be appreciated.
Old Aug 7, 2002 | 11:12 PM
^ Help still required.
sinistersam
Sep 13, 2015 07:17 PM
The1Sun
Sep 7, 2015 10:21 PM
risingsunroof82
Sep 7, 2015 01:11 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
