Wierd RPM drop
Old Jul 31, 2002 | 10:09 PM
Manntis's Avatar
add to cart
Wierd RPM drop
This happened once yesterday, then again today.
I pull onto the freeway and accellerate. At about 60kph my RPM's drop by about a grand, even though I continue accellerating.
Anyone else experience this? It's like the reverse of a slipping clutch. Vacuum leak, maybe?
Old Aug 1, 2002 | 08:02 AM
1_dollar_83_RX7's Avatar
or a messed up tach
Old Aug 1, 2002 | 08:21 AM
MyRxBad's Avatar
EliteHardcoreCanuckSquad
I think the tach is sticky.
Mine is sticky right now too, but mine sticks when it's coming down from to idle. Instead of sitting at 900 rpms or so, it sits up @ about 1500.
Yours might be high at idle and then when you accelerate (after a certain point in the tach) it settles back into to normal.
Old Aug 1, 2002 | 12:07 PM
Jeff20B's Avatar
Lapping = Fapping
Weird. I've got a Sun tach II that sticks at 3k RPM for a little bit after you rev it up and let it settle back to idle.
Old Aug 1, 2002 | 01:55 PM
Manntis's Avatar
add to cart
The tach isn't sticking - as I said the RPM's DROP. I not only see it on the tach but hear it in the revs.
Old Aug 2, 2002 | 06:35 AM
djmickyg's Avatar
Question
are ya 5 and 6 port, blocked?
Old Aug 2, 2002 | 01:29 PM
Manntis's Avatar
add to cart
hmmm... worth investigating.
Old Aug 2, 2002 | 09:55 PM
TheBattlePenguin's Avatar
I talked to a dealer one time that said some of the 1st and 2nd gens experiences an rpm drop around 3000k becasue the primary ground wire came loose. You might want to check this and scrape any corosion off it.
Old Aug 2, 2002 | 10:53 PM
Rotor13B's Avatar
Wassup!!
Jeff20B Weird. I've got a Sun tach II that sticks at 3k RPM for a little bit after you rev it up and let it settle back to idle.
Well there's your problem,lol
Old Aug 3, 2002 | 12:43 PM
MyRxBad's Avatar
You have a magical overdrive.....
You got me stumped on this one.
Which gear were you in? Is your timing advance working? Keep us up to date.
Old Aug 3, 2002 | 01:56 PM
Manntis's Avatar
add to cart
I'm thinking slipping clutch.
I was in 3rd gear
alexdimen
20
Oct 23, 2015 01:50 PM
The1Sun
Sep 18, 2015 07:13 PM
xXBrendanXx
Power FC Forum
Sep 17, 2015 10:10 AM
firzen
Sep 15, 2015 12:04 PM
gabescanlon
Sep 5, 2015 12:09 AM
