Variable Resistor
Old Jul 29, 2002 | 06:46 AM
CrackHeadMel's Avatar
Learned alot | Alot to go
Variable Resistor
Just a quick question, what is the variable resistor? specificly the one (if there are more than one) next to the passenger side shock tower
Old Jul 29, 2002 | 06:56 AM
silverrotor's Avatar
It Is a Idle mixture adjuster. In the center of It lies a screw that could be turned clockwise/counter-clockwise. L- lean and R-rich are on opposite ends od the Variable Resistor. This only affects Idle! Nothing more.
If you change the pre-existing settings, be sure to connect jumper wires at the Initial Set Coupler, readjut your TPS and Idle speed, as from the FSM.
If It has never been tampered with before, chances are you don't need to touch It!
Old Jul 29, 2002 | 09:01 AM
Thanks, i dont plan on changing it, i was labling everying as i unpluged it and realized that i had no idea what it was
Thanks again
kuuva86
Sep 28, 2015 05:42 AM
FC_DREAMS
Sep 9, 2015 06:24 PM
