Would like to run 13.5 @ ~105 1/4 mile
Old Jul 28, 2002 | 10:13 PM
Rx-7Addict's Avatar
Rotary Powered
I have about $1200 to spend.
How does racing beat turbo back, FCD, intake, fuel pump, GSL-SE injectors, and a S-AFC (or equivelent(sp)) sound?
Any advice on similar setups will be nice. This should be good for 250+ crank HP.
Old Jul 28, 2002 | 10:33 PM
Rxmfn7's Avatar
Do a barrel roll!
Borrow someones stock FD
Seriosly though, those mods and maybe a set of drag radials....if everything goes perfectly you should be very close to that.
Old Jul 28, 2002 | 10:42 PM
no way $1200's gonna get you all that.. well unless you buy the exhaust used or something..
anyway, I'd lose the intake. The exhaust alone will put you over 11 psi on a good s4. Boost levels above that on the stock turbo can be unsafe even if you have the fuel.
However, if you really port your wastegate, you might be able to manage a full exhaust and intake with safe boost levels..
good luck.
Old Jul 28, 2002 | 10:45 PM
Barwick's Avatar
SCCA Rookie
you can't get all that stuff for $1200, unless it's used. PLUS the Racing Beat (while it IS the best) is on a fairly large backorder right now.
Oooh.. Cleveland.. when I'm back in town I'll have to look you up.
Old Jul 28, 2002 | 11:37 PM
Rx-7Addict's Avatar
Rotary Powered
so my estimate was slightly off
RB turbo-back ... $750
fuel pump........... $100
intake................. $150
S-AFC.................. $300
FCD..................... $80
injectors.............. $100
So almost 1500.... hmm
Well how do those mods sound together at least?? Is it adequate fuel mods for the gain in power?
Old Jul 28, 2002 | 11:44 PM
Rpeck's Avatar
What R U thinking self?
Racing beat is only at -14 right now .. about a 3 week wait. Not bad considering its the best.
Old Jul 28, 2002 | 11:46 PM
Ryde _Or_Die's Avatar
Your looking at the same basic setup I have in mind. The fuel should be good with that. Controlling the boost will be the problem. Porting the wastegate will be a good idea. The thing you have forgotten unless you already have them are gauges. Very important to know how much boost you are running and how rich or lean. I've got everything you are looking at getting except the s-afc and the catback. Once I get my gauges in and see what levels I am running I will go from there. With my tires I hope for a low 14 now. If I get that I will be very happy.
Old Jul 28, 2002 | 11:56 PM
Rx-7Addict's Avatar
Rotary Powered
Thanks, Ryde or die
I would be real happy with a 14.0
I like the RB turbo back. Its quiet and includes downpipe, midpipe, catback all for a good price (under $800).
As for the gauges, I forgot to mention them.
A boost gauge is a definate, esp. since the FCD disables the stock gauge. Also I plan on getting an A/F gauge for now, and hopefully be able to get an EGT gauge later (they are expensive)
Old Jul 29, 2002 | 12:07 AM
MaxRX7's Avatar
hambre y sueño
not my choice, but "NOS" is the cheapest way to go fast.
ps: I like the direction you are taking
Old Jul 29, 2002 | 12:45 AM
fcturbo2's Avatar
Hey you forgot labor, shipping, tax =)... Unless you want to install the RB full turbo back exaust by yourself then forget about the labor. I have the RB system in my TII and i can tell you that the quality of steel they use is very good and heavy.
Ohhh and with the SE injectors you probably want to send them out to RC to have cleaned and calibrated. That is over 50 bucks for the pair. You want to do this to make sure its not leaking.
The rest of the parts you can probably do yourself installation.
GOing fast isnt going to be cheap. Good luck...
Old Jul 29, 2002 | 01:08 AM
Rx-7Addict's Avatar
Rotary Powered
Am I getting in over my head thinking I can install an exhaust system myself?
Old Jul 29, 2002 | 01:09 AM
Rpeck's Avatar
Putting the exaust system on yourself is a cake walk .. the hardest part is getting a jack or a buddy to hold up the back while you bolt it up front. Otherwise .. prolly the easiet mod you can do for such a great power gain. If it takes you more than 1.5 Hrs MAX your handy. Sometimes the stock exaust is a bitch to break the bolts loose, soak them good the nite before & a air gun will help. But, DON"T use a air gun if the bolts are in really bad shape .. you will strip them to ****.
Bolts ... Nuts you know what I mean. Same only different.
Old Jul 29, 2002 | 04:05 AM
fastrotaries's Avatar
W. TX chirpin Monkey
instead of the RB turbo back i used a thunderfabrications 3" DP to cat-back pipe and an N1. intake, G-force. NO FCD and ran 14.0 all day long. to run efficiently run 13.5's your gonna have to probaly uopgrade your stock turbo. You could do it. But not consistantly in warm weather. That's a great start though.
Old Jul 29, 2002 | 12:19 PM
UniqueTII's Avatar
Slow and old
$150 for an intake...scrap that idea. Get an adapter plate and a cone filter. That'll free up some other cash for more fun things.
I don't think you'll need to upgrade your injectors yet, either. A better pump, rewired, with an S-AFC should be enough fuel for the 275hp range you will be expecting. My car has a totally stock fuel system and runs 14.12 in the quarter...whether or not it'll last is another issue, but an S-AFC and pump would be all I'd need to upgrade right now.
Old Jul 29, 2002 | 12:45 PM
ponykiller's Avatar
Go with a series 5 turbo!
A friend of mine was running low 13s on a 10th anniversary RX7. The ONLY mods he had were a S5 turbo, cone intake, and a full exhaust (including an N1). He eventually blew his engine, but he was running damn fast for only $700. From my experience, the N1 flows the BEST for all catback systems. Also, you can have a muffler shop make you a downpipe and midpipe for $50. There is no need to purchase the RB full exhaust.
So, my recomendations:
S5 turbo
4X 550cc injectors (off of an S5 TII)
larger fuel pump (an FD fuel pump would work very nicely for this setup)
cone intake (do not pay any more than $50)
downpipe/midpipe (made by an exhaust shop-do not pay more than $70)
cat-back (The N1 flows the best, but it is a little pricey and loud. Whatever catback you get, just be sure it is a single side exit catback, as it flows better than dual and weighs less)
Best of luck to you,
Kris
PS-My friend is an incredibly good driver, so those mods should easily put you in the low 14s, and with practice (the cheapest mod) you can break into the 13s.
Old Jul 29, 2002 | 12:55 PM
UniqueTII's Avatar
Slow and old
S4 TIIs have 4x550 injectors, so you shouldn't have to replace them.
Old Jul 29, 2002 | 01:14 PM
1_dollar_83_RX7's Avatar
I would get the
exhuast- $750
DIY FCD - $20
safc - $300
walboro 255 - $120?
DIY TID - $50
thats $1240. and then get some 720cc injectors anda boost and a/f gauge
$1500 max for everything!
also..port the wastegate with a dremel
Old Jul 29, 2002 | 01:42 PM
UniqueTII's Avatar
Slow and old
I have an FCD I'll sell you...I could drop it off on my way through OH in August.
Old Aug 27, 2002 | 09:22 PM
Rx-7Addict's Avatar
Rotary Powered
Wanted to bump this, and now that I have the money, here is what I am likely getting
K and N cheap intake... $50
DIY TID................. $20
Fuel pump ......... $100
***what kind??
FCD. $80
autometer gauges...... $100
Looks like $1400...
any suggestions or changes? I want this affordable as possiable, obviously
Old Aug 27, 2002 | 09:25 PM
RETed's Avatar
+$300 for a new clutch
-Ted
Old Aug 27, 2002 | 09:39 PM
Wankel Traitor
good thinkin there ted
Id go with:
Corksport Single Exhaust: $300
ThunderFabrications DP/MP: $200
Cone Filter: $20
FCD:$100
Walbro fuel pump: $130
S-AFC: $325
Clutch: $300
That'll do ya and keep ya safe if you are a good driver .
Jameson
Old Aug 27, 2002 | 09:42 PM
BoostedRotors's Avatar
I HATE sleepy eyes
I essentially have that setup on my FC along with a large street port and minus the S-AFC. I havent run it at the track, but Id guesstimate its runs mid to high 13's, based on cars its beaten.
Old Aug 27, 2002 | 09:43 PM
Agent_D's Avatar
rawr
if its an 88 TII will the GSL-SE 680cc injectors work?? i thought all 2nd gens past 87.5 had high impedance injectors, and im pretty sure the GSL-SE has lower imp, but i could be wrong
Old Aug 27, 2002 | 09:44 PM
Felix Wankel's Avatar
Super Newbie
Thats what resistors are for!
Old Aug 27, 2002 | 09:52 PM
kabooski's Avatar
Laying Down Rotary Law
Eh Hey! I ran 13.5@105MPH what do you know
on plain O' street tires
$300 in external mods
$200 in a custom single no cat exhuast
$100 HKS Intake
But in all fairness lol I had a "Mild" Ported Engine
-Polished Intake
-Ported Exhaust
Get a 3" Ultra or Magna Flow Muffler (2) if you wish..
Buy the RB Y pipe and DP with Silensor
Set of 720's
A ECU Chip
