A few pictures of my new TII...
Old May 29, 2009 | 01:03 PM
  #101
Alex Rodriguez's Avatar
MODERATOR
Veteran: Marine Corp
wooow very nice
Old May 29, 2009 | 08:22 PM
  #102
Twins80s's Avatar
I
damn that thing is on a whole nother level!
Old Jun 12, 2009 | 02:27 PM
  #103
digitalsolo's Avatar
RX-347
Killed a rod bearing in the car last week at the strip. I did manage to knock down a 12.3 @ 112 mph on an aborted pass (7.99 1/8, should have been a ~11.80 @ 125 mph). Not bad 5-6 psi and a 6 speed.
Going to be putting together a fully forged wiseco/callies setup in an aluminum 5.7L block over the next couple months and bring it back out with a proper bottom end.
Should go mo' faster. I'm expecting 700-750 RWHP out of the 347.
Old Jun 12, 2009 | 08:58 PM
  #104
RRTEC's Avatar
Rotartist
How long till she's back up?
Old Jun 13, 2009 | 12:30 AM
  #105
siguy2k's Avatar
SLEEPER
Very nice build and im not usually a fan of v8 7's!!!! What seats do you have in it?
Old Jun 13, 2009 | 08:25 PM
  #106
RX-347
Seats are 300ZX TT out of a '95.
It should be back up in a 5-6 weeks. Gotta get some cash together and get the engine put together. Lingenfelter and EPP are doing the build. Should be stout.
Old Jun 13, 2009 | 09:19 PM
  #107
beefhole's Avatar
Boosted. I got BLOWN!!!
GAHHH!!
Try not to alter the rotation of the earth. OK please?
Old Jun 14, 2009 | 09:46 PM
  #108
RRTEC's Avatar
Rotartist
There is a sweet Lingenfelter supercharged vette running around this area.. He also pumps nitrous in there... Crazy I saw him run a ViperGTS down the interstate, it was just a blur of yellow and he was gone...
Old Jun 14, 2009 | 10:06 PM
  #109
bl00dlust's Avatar
oh my lord. i dont think ive ever been in love with an FC as much as i am yours and its not even a rotary. i feel dirty.
no really though, GREAT looking car! post some videos of that bad boy.
It's probably been answered before but, what kit do you have on there? it looks so good. i just wanna eat your car up.
Old Jun 15, 2009 | 12:28 AM
  #110
MaczPayne's Avatar
Mac Attack
Forget G's, this car is going to pull stumps!
Old Jun 15, 2009 | 09:09 AM
  #111
RX-347
Thanks guys.
The body kit is AIT Racing/BMagic.
There are some videos of the car up at www.ls1fc.com in the "videos" section.
-Blake
Old Jul 28, 2009 | 12:34 PM
  #112
RX-347
Well, the engine is down at Lingenfelter for the machine work, all the parts are in now (minus bearings and crank damper). Should have it in the car in a few weeks.
While it was down, I redid all the chassis wiring, repainted the engine bay and cleaned up a few loose ends. Just need to touch up a few little details in the bodywork and the car should be ALMOST where I want it to be.
Old Jul 28, 2009 | 01:26 PM
  #113
RRTEC's Avatar
Rotartist
killer... Hope all goes well with the build.
Old Aug 20, 2009 | 11:24 AM
  #114
RX-347
Engine build last weekend:
ARP cam bolts, GM HD Chain, GM HV Oil Pump:
ARP studs, Compstar Rods:
Wiseco 2618 forged/coated -25cc pistons:
MLS gaskets with copper spray, ARP 12 point head studs:
And a bit more progress last night:
Heater hoses and harness entrances into the interior relocated; There is a piece of 1/8" steel on each of these (riveted on the harness and bolted on the heater hoses) to reinforce where the grommet seals them (since the Mazda metal is like tin foil). I don't run A/C, so the heater hoses were relocated to this location for ease of access.
They are VERY snug in the mounts and secured in the rear with clamps so that they are very easy to install/remove the hoses from for service.
The factory harness hole has been sealed off from the bay.
Bulkhead fitting for oil pressure gauge; I don't like electrical oil pressure gauges as I've had weird electrical issues in the past, and it perturbs me when the gauge reads incorrectly. I also don't like cheesy copper lines full of oil in my interior or holes in the firewall. Solution? AN fittings, braided line and a bulkhead fitting.
Here you can see it attached to the factory pressure port on the LS1; there is plenty of slack to allow for engine movement, though my mounts keep it pretty well secured.
Long block in place, I repainted the engine bay and cleaned up a few things I didn't care for in there while the engine was out:
Old Aug 20, 2009 | 11:26 AM
  #115
RX-347
And the intake, fuel system and electrical installed. Unfortunately there was an ordering error on my crank pulley, so I cannot complete the cooling/turbo installation until it arrives as it would be rather unenjoyable to install the pulley with a pipe 3" in front of it.
I'm going to put the vacuum bulkhead (for boost gauge and controller) in the firewall tonight, as well as the driveshaft and engine and transmission oils. I'm also still waiting on a billet vacuum distribution block which should tidy up my vacuum situation (was rather messy before with lots of "T" fittings) so that I can complete that setup. Just a couple more hours of labor once the pulley and vacuum block arrive.
Old Aug 20, 2009 | 08:55 PM
  #116
siguy2k's Avatar
SLEEPER
Looking really good! Your car is the only rx7 ive liked without a rotary!! Cant wait to see some #s and videos! Awesome car man!
Old Oct 23, 2009 | 12:33 PM
  #117
RX-347
Well, the car is back apart (somewhat) for this winters changes.
Converting the exhaust to come out the back (currently dumps after a bullet muffler, in the center of the car just behind the doors. Just want to quiet it down a bit.
Removing ALL extra wiring from the car, tucking the chassis harness in the engine bay, and sleeving and tucking the engine harness in the bay.
Lowering the seats 1" to get more head clearance.
Installing a 2 step.
Installing an alkycontrol injection system.
Tweaking a couple things on the turbo kit.
Detailing the interior.
Detailing the exterior.
More stuff I'm surely forgetting. I'll post some more up once I get pictures of the progress.
Old Oct 27, 2009 | 11:10 AM
  #118
RX-347
Progress:
Redoing the entire harness with sleeving and heat shrink (glue filled):
Culling all unused wires from the entire harness (chassis and engine).
"Tucking" the engine bay harness and fuse block (NO visible wiring in the engine bay).
Installing methanol (alkycontrol) and Lingenfelter 2 step launch control/rev limiter:
What fun is a completed project, right?
Old Oct 27, 2009 | 01:59 PM
  #119
dkwasherexd's Avatar
Garage Life
siickk. I bet there will be alot of haters tho haha
Old Oct 27, 2009 | 03:02 PM
  #120
RX-347
You know, I've honestly ran across one or two people total that actually talked much trash, and most of them talked it about me more so than the car.
But hey, if people don't like it, more power to them, just build something better before you talk smack.
Old Nov 1, 2009 | 09:03 PM
  #121
RX-347
Okay, making some progress:
Interior wiring; still a lot to do here, all the extra stuff is pulled out now though. The wiring for the Autometer/VDO gauges is the loose wiring on the column; it will be terminated into a metripack 10 way connector to plug into the gauges.
The fuse block and relays to control the HVAC (I removed the factory primary relay) and LS1 harness will be mounted on the plate where the factory harness connectors for the wipers, etc. originally mounted.
Relocated OEM fuse box for main fuse, headlights, retractors, etc; this is covered by the shrouding, so you can't see it when the bay is put together.
Boost control solenoid. I still need to put a metripack connector on the solenoid itself, you can see the lead for the controller merged into the F-Body harness:
Lingelfelter 2 Step controller, fully wired, along with all driver's side fuel injector, coil driver and other various sensor wiring:
Passenger wiring:
And an overall:
There is still a lot of cleanup to do, as well as finishing up the coil driver to coil harness and dressing in a few things. Couple of paint glitches in the rocker covers that need cleaned up, nothing too major.
I'll post up a finished pic of the interior wiring once it's totally sorted out. Also of merit, the wiring you see in the engine bay currently, is all the wiring there is, the rest is either in the fenders or on the interior side of the firewall.
Old Nov 1, 2009 | 09:37 PM
  #122
hkp's Avatar
hkp
big turbo spoolin
your car is awesome, looking forward to seeing some highway pull videos.
Old Nov 15, 2009 | 12:49 AM
  #123
RX-347
Bling, bling.
Scotch mylar tape for aerospace.
Old Nov 17, 2009 | 03:02 PM
  #124
91TIIRx-7's Avatar
im not a fan of v8s in 7s but this one is good stuff, very nice set up.
Old Nov 17, 2009 | 04:05 PM
  #125
RX-347
Thanks, it's getting there.
Next up is probably a swap to a C4 Corvette rear end for some better gearing and better strength.
