Megasquirt MS1 pnp Help Needed.
Old Jul 4, 2010 | 08:36 AM
  #51
12AllWays's Avatar
It means 12A all ways^
You mean since I had it running the other day then the grounds must be fine? I will get it shipped out Monday first thing.
Thanks
Keith
Old Jul 4, 2010 | 10:19 AM
  #52
muythaibxr's Avatar
MegaSquirt Mod
Not necessarily must be, just very likely.
Ken
Old Jul 6, 2010 | 01:59 PM
  #53
12AllWays's Avatar
Shipped out to Ken today. Will be there in a few days max...
Thanks
Keith
Old Jul 10, 2010 | 10:59 PM
  #54
12AllWays's Avatar
Any word on that MS Ken?
Thanks
Keith
Old Jul 13, 2010 | 08:52 AM
  #55
muythaibxr's Avatar
MegaSquirt Mod
I think they tried to deliver it on Friday, but I have not had a chance to get to the post office yet.
I'll go there today or tomorrow and pick it up.
Thanks,
Ken
Old Jul 15, 2010 | 08:49 PM
  #56
muythaibxr's Avatar
MegaSquirt Mod
Alright, I picked it up this morning (sorry it took so long, work has been nuts).
I'll get a look at it this weekend and fix whatever is wrong, and send it back early next week.
Ken
Old Jul 15, 2010 | 09:25 PM
  #57
12AllWays's Avatar
Ken
No big deal, Thanks so much for checking it out, let me know how it goes.
Keith
Old Jul 19, 2010 | 10:15 PM
  #58
muythaibxr's Avatar
MegaSquirt Mod
So I checked all the wiring and it all looked fine, but the hysteresis potentiometer was turned pretty far clockwise. I turned that counterclockwise all the way, and will test in my car tomorrow evening after work.
Ken
Old Jul 20, 2010 | 09:49 AM
  #59
12AllWays's Avatar
Ken
Awesome, Let me know how it turns out. Would that make it do wierd things?
Thanks
Keith
Old Jul 20, 2010 | 02:09 PM
  #60
muythaibxr's Avatar
MegaSquirt Mod
It could if your CAS's sensor gap was just on the high side of the spec.
Ken
Old Jul 22, 2010 | 10:38 PM
  #61
12AllWays's Avatar
How did it run on your car?
Keith
Old Jul 23, 2010 | 10:08 AM
  #62
muythaibxr's Avatar
MegaSquirt Mod
I've not actually had a chance to try it yet. I've had to work late every day this week so by the time I get home, it's too late to start a loud car in my townhouse neighborhood.
I'll keep you up to date, sorry it's taking so long.
Ken
Old Jul 23, 2010 | 05:27 PM
  #63
12AllWays's Avatar
Its all good. No rush, let me know how it does.
Thanks
Keith
Old Jul 24, 2010 | 08:52 PM
  #64
muythaibxr's Avatar
MegaSquirt Mod
Ok, it starts my car just fine every try. It is on its way back Monday.
Ken
Old Jul 24, 2010 | 10:10 PM
  #65
12AllWays's Avatar
Sounds good man. Ill pm ya.
Old Jul 24, 2010 | 10:38 PM
  #66
12AllWays's Avatar
Oh and how was the adapter and wires? Did you change it any?
Old Jul 25, 2010 | 07:15 PM
  #67
muythaibxr's Avatar
MegaSquirt Mod
The adapter and wires seemed fine. I tried wiggling them and stuff and couldn't cause any problems.
I did 2 things since I had it here. The first was turning the hysteresis pot on the Ne sensor input to fully counter clockwise (which is what fixed the problem).
I also put a jumper to ground on pin 14 of the lm1815 circuit. This reduces noise on the 2nd trigger, and while you didn't NEED this, it should make starting more reliable if you had noise issues.
Ken
Old Jul 25, 2010 | 09:05 PM
  #68
12AllWays's Avatar
Sounds Great man. Cant wait to get it back and get tuning.
Keith
Old Aug 4, 2010 | 07:35 PM
  #69
12AllWays's Avatar
Got the MS today, works great, I will be tuning tomorrow.
Thankyou Ken. You are the man. Pm me for shipping costs.
Keith
Old Aug 5, 2010 | 02:15 PM
  #70
muythaibxr's Avatar
MegaSquirt Mod
Glad it's working for you. Let us know how tuning goes.
Ken
Old Aug 5, 2010 | 10:33 PM
  #71
12AllWays's Avatar
Tuning is good so far, messed with the low boost/no boost fuel all day when driving, then tonight I started with the WOT got it holding 10.8-11.3 afr all the way to redline at 13-14 psi. Pulls really strong, although it seems the boost has hit a brick wall at 14 psi, I had the boost controller turned as far as it would go to up the boost and 14 was as high as it would get.
I do have a small exhaust leak between the engine and manifold, that must be holding the boost back...
Old Aug 6, 2010 | 05:10 AM
  #72
clint999's Avatar
How does this look as far as settings and what not? Too much fuel for 720 primaries?
rx7 turbo.zip
Old Sep 29, 2010 | 03:39 PM
  #73
12AllWays's Avatar
Now that its becoming colder I have noticed it takes longer to start the car. Its pretty good once its running so I think the after start enrichment is good.
I would assume I need to adjust the cranking settings injector ms for lower temps. Which way should I go with the values to make it richer? Higher or lower ms?
Old Sep 30, 2010 | 09:29 AM
  #74
muythaibxr's Avatar
MegaSquirt Mod
Higher pulse width is richer.
Ken
Old Sep 30, 2010 | 09:51 AM
  #75
12AllWays's Avatar
Thanks Ken.
