Nitrous Oxide Injection on a Rotary
Old Apr 18, 2003 | 09:36 PM
  #51
c-squared's Avatar
Originally posted by chris_stampe
You should make one of these for TII people.
Sean's no longer on this forum, but I talk to him pretty regularly, as we work together.
Nitrous on a TII doesn't really make sense, given the already existant creep issues. The addition of nitrous gases to the system would cause creep on any stock wastegate, no matter how radically ported.
Sean played with it because he was ******* nuts. He's EXTREMELY lucky he did not blow his engine, considering his boost conrtol issues on a disgustingly large port job on an S5 wastegate.
BTW... I am pretty sure he still answers his email at shutup_billy@hotmail.com.
Old Jul 6, 2003 | 02:15 AM
  #52
DEZERTE's Avatar
777** The Anti-rice
Does anybody know which injectors to upgrade to, to provie adequate fuel for a 50-75 shot on an S5 NA
Old Aug 4, 2004 | 06:57 PM
  #53
SwooshMan's Avatar
I'm bringing this one back i know! A friend of mine is going to be installing a wet kit, where should we be getting fuel from?
Old Aug 6, 2004 | 08:55 PM
  #54
jhillyer's Avatar
Denaturing with sulfur dioxide results foul odor and lung irritation by forming a mild acid. It remains sniffable.
Old Mar 17, 2007 | 11:28 PM
  #55
Rotary_Powerd's Avatar
Bringing this back from the dead in part because it deserves a bump and in part because I have a question. I knew to the FC's intake system, does the car have a MAP or MAF sensor? I the 2nd case, I would guess that the MAF would pick up the increase air flow and temperature drop and compensate the fuel correct? (assuming injectors and fuel pump are in working order).
I'm not new to nitrous by any means, just to rotaries, anyways would a 25 or 35 hp dry shot be a problem for fuel compensation? Yes that's all I want a nice small shot, to complement bolt on's and give around 200hp at the crank. That would make me more than happy
Old Mar 17, 2007 | 11:59 PM
  #56
NZConvertible's Avatar
I'm a boost creep...
Originally Posted by Rotary_Powerd
...does the car have a MAP or MAF sensor?
Both. The primary load sensor is an AFM (but a flap type, not a MAF (hotwire) type), and there's a MAP sensor for secondary functions.
No, becasue nitrous doesn't increase the airflow into the engine. Nitrous is an oxidiser (it contains it's own oxygen) which allows you to add more fuel. More fuel burnt makes more power. The extra fuel must be added by the nitrous system and the fuel pump must be able to keep up with the extra flow. If you're familiar with nitrous you should know this...
Old Mar 18, 2007 | 12:31 AM
  #57
mightymite's Avatar
speakn of n2o could you run like a 10shot for a full 60 seconds for like a autox?
Old Mar 18, 2007 | 12:46 AM
  #58
fastrotaries's Avatar
W. TX chirpin Monkey
irunning a full shot of N2O in an Autocross would be dificult since the SCCA doesn' t allow the use of Nitrous. Last I checked it was illegal in both Solo II and Pro-Solo. Don't know about the other classes but I expect the same. Although small, a shot of nitrous is really abrupt and rather instant. mid corner it'd be tough to compensate. I would spend my money on grip instead.
Old Mar 18, 2007 | 10:25 AM
  #59
I respectfully disagree, yes nitrous oxide is an oxidizer that breaks down at over 500 degrees, however the initial exposure of the liquid to the ambient atmosphere, will drawn in alot more air.
Because nitrous is so cold; it absorbs alot of heat around it, thus condensing the air that is at atmospheric pressure and increasing the air flow. The air entering the manifold is alot more dense because of nitrous use.
Thank you for answering my other question though.
Old Mar 18, 2007 | 10:37 AM
  #60
Aaron Cake's Avatar
Engine, Not Motor
Copied to Archives.
1987 T2
11
Apr 1, 2017 11:59 PM
doritoloco
Sep 5, 2015 12:41 PM
rotor_veux
Sep 3, 2015 07:10 PM
Murilli
Midwest RX-7 Forum
Sep 3, 2015 09:10 AM
