(ENGINE) Cleaning and painting a 12A
Old Feb 6, 2008 | 08:39 PM
Rx7carl's Avatar
Airflow is my life
Looks nice! Also engine paint is fuel and oil resistant. Very important to keeping a nice finish.
Old Feb 6, 2008 | 08:46 PM
blwfly's Avatar
kiwi from downunder..
wow didnt know that.
Old Feb 6, 2008 | 09:41 PM
vipernicus42's Avatar
Rotoholic Moderookie
Sweetness. Looks good like that Good work man!
Jon
Old Feb 21, 2008 | 09:53 PM
  #29
defiant13's Avatar
I'm in the process of doing the same. Looks really good man.
Old Feb 21, 2008 | 10:03 PM
  #30
MattG's Avatar
MattG FTW!!!!!
So, your gonna come do mine right?
Old Feb 21, 2008 | 10:44 PM
  #31
teddyrx2's Avatar
One Luv "Till The End"
very clean motor
Old Feb 21, 2008 | 11:20 PM
  #32
blwfly's Avatar
orded up some gaskets for the water pump couple shims clutch aligment tool new polit bearing and seal manifold gasket
can i get away with just a silicone sealer on the oilpan?? or do i need a gasket.
need to get come more black paint and clear paint.
Old Feb 21, 2008 | 11:23 PM
  #33
blwfly's Avatar
sure come pay my rent.
Old Feb 21, 2008 | 11:43 PM
  #34
teddyrx2's Avatar
im next
Old Feb 22, 2008 | 12:41 AM
  #35
BlackWorksInc's Avatar
Wrkn Toyota, Rootn Wankel
Wow... that looks a lot smaller all cleaned up!
Guess after you get the one inch thick cake of grease off the engine does shrink a lil!
Nice work!
Old Feb 22, 2008 | 01:41 AM
  #36
MattG's Avatar
MattG FTW!!!!!
If you can get mine looking like that, then you got your self a deal!
Heres what you got to start with
Old Feb 22, 2008 | 06:39 PM
  #37
blwfly's Avatar
might want to put some muratic acid on this one.
Old Feb 24, 2008 | 11:10 AM
  #38
blwfly's Avatar
got my gaskets and piloet bearing etc.
need to sand up and paint my oil pan water pump/housing and couple other things..
my clutch and pressure plate had rust on them only sand paper i had is 400 will the clutch be fine and not glaze or should i take like a 100 grit to it.
dose anyone thing i can get away with just gasket sealer on the oil pan?
heres my carb i have moded i need to disasemble it and sand all the rust off and give it a clear coat.
Attached Thumbnails (ENGINE) Cleaning and painting a 12A-cimg0703.jpg   (ENGINE) Cleaning and painting a 12A-cimg0705.jpg
mazdaverx713b
48
Apr 21, 2016 06:45 AM
