A Basic Tear Down, Port and Rebuild (what to look for and how to)
Old Feb 9, 2007 | 01:36 AM
RotaryEvolution's Avatar
Sharp Claws
slap the hell out of people who start messing with work in progress?
that's a wierd one that i never heard of also Kevin, wonder if this one is related to that issue.
Old Feb 9, 2007 | 01:38 AM
iceblue's Avatar
Passing life by
RR - I will inspect again in the morning just because this is bugging me. The plates in the rear were realy good IMO and the front was trashed. The owner forgot to order and install the buttons as well.
Old Feb 9, 2007 | 01:42 AM
RotaryResurrection's Avatar
What, you mean the rubber plugs? I havent used those damn things since 2001. They are utterly useless. IN 10k miles they are hard as a rock. Their (supposed) jobs are to create compression and keep carbon from building up under the apex seal. Yet we know that a shitload of carbon builds up in the slot on stock original motors, and we also know that building engines without them do not suffer any compression loss (in my experience).
Also with even moderately ported engines they can become a liability, falling into the port.
Yeah, I know what you're gonna say..."oh, the factory put them there for a reason". Yeah, the same factory that put AWS and the thermal pellet in the e-shaft.
Yeah, theyre only $20 extra, but 20 here and 20 there, it all adds up.
Old Feb 9, 2007 | 01:47 AM
  #29
iceblue's Avatar
Passing life by
Yeah I know not needed it was just to state that another portion was forgot.
Old Feb 9, 2007 | 02:49 AM
  #30
wiL87's Avatar
wow ice, this is a grreat thread. it would be better if you stated why some of the parts failed.. you know for the nubs xP <----
Old Feb 9, 2007 | 07:17 AM
  #31
My5ABaby's Avatar
Rotaries confuse me
I love this thread. +1 to the awesomeness
I also like how several builders are submitting their input.
Old Feb 9, 2007 | 12:33 PM
  #32
Oogly Boogly's Avatar
Mine started to go hard at 3000 mi. or so. I would be skepticel about not putting them in.
Old Feb 9, 2007 | 12:57 PM
  #33
nik's Avatar
nik
Just a quick question, when you are measuring the oil control rings with the calipers I am not quite sure what spec you are trying to meet? This doesn't look like the lip width check the manual describes. If it is, then why do you say they are fine when it says max 0.020 inch, and your caliper is reading well above that?
Old Feb 9, 2007 | 01:00 PM
  #34
^^I always thought it was the wear lip
Old Feb 9, 2007 | 01:05 PM
  #35
nik's Avatar
nik
Exactly, I always measure the width of the wear. That's why they show to do it with a magnifying glass. It could just be a misunderstanding however, maybe wrong pic posted or something, but should be fixed in a howto thread.
Old Feb 9, 2007 | 01:31 PM
  #36
iceblue's Avatar
Passing life by
Hey nik I checked both and the lip is mesured for consistancy it should all be in the photos.
Old Feb 9, 2007 | 01:38 PM
  #37
slpin's Avatar
7th Heaven
and to comment on the way how you 'rebuild' motors
you dont just toss all the seals in a cup and wash it
there are 12 corner seals, 3 to a set, and each set have to be on the same face iron.
as with apex seals, they have to be on the same rotor
sideseals, same story as corner seals - theres a reason people put seals and mark their location.
Old Feb 9, 2007 | 02:08 PM
  #38
iceblue's Avatar
Passing life by
I am sorry about that guys! I uploaded the wrong inspection folder in the mits of 100 pics. Here is the correct order if a Mod would not mind correcting it.
Oil control rings were great also.
Inspect the seal width for consistency and warpage.
Old Feb 9, 2007 | 02:10 PM
  #39
It's not really that critical at all, especially if all the parts have the same mileage. I don't use the seal case either.
Old Feb 9, 2007 | 02:19 PM
  #40
iceblue's Avatar
Passing life by
I notice I also did not point out one rotor was S4 NA and the other was S5 NA. The oil pump chain also had 3/4in slack way to much.
Old Feb 9, 2007 | 03:13 PM
  #41
nik's Avatar
nik
Makes sense now, thanks
Old Feb 9, 2007 | 03:47 PM
  #42
ultrataco's Avatar
r o t a r y
wow, very informative. keep it coming!
I now know I don't want to try rebuilding a motor myself.
Old Feb 9, 2007 | 03:50 PM
  #43
Richter12x2's Avatar
Taste great, more filling
You know your skills better than anyone else, but I was surprised how easy it was. If you're patient, observant, and careful, it's a breeze.
Old Feb 9, 2007 | 04:14 PM
  #44
This from the man that's re-rebuilding his engine with a fresh intermediate iron
Sorry, I couldn't resist
Old Feb 9, 2007 | 04:33 PM
  #45
spot_skater's Avatar
The Cause of Death
Great thread.
Glad to see the more experienced builders giving input and sharing ideas with each other.
James
Old Feb 9, 2007 | 05:40 PM
  #46
I know, I know - make fun. All I can say is I showed all the irons to three different people and noone could see anything wrong with it. :P It was a one in a million break and the iron looked absolutely fine. I pored over everything with a flashlight and couldn't find anything wrong.
In fact, I eventually reassembled it over the kitchen sink so that I could see where my water leak was coming from. :P My wife thought it was funny and took a picture of it.
It held water until it was almost to the top of the water pump inlet before it started to leak between the intermediate iron and the rotor housing. So I took it apart and looked all over that side of it. I couldn't find anything wrong! So I took some 80 grit sandpaper and sanded every water passage on that side of the bottom of the intermediate iron smooth so I could tell there weren't any cracks in it. Nothing! So I presumed my RTV was leaking and started to clean it up again. When I was scraping out the seal groove on the intermediate housing, I just happened to see it flex, just a little bit. So I pushed on the wall and it flexed when I pushed on it. :P Then it broke off. There was a hairline crack at the bottom of the seal passage and the weight of the water was causing it to flex just enough to run out underneath it. :P
So I don't feel too bad about missing that on my first rebuild. Especially since it lasted through 500 miles and two Solo 2 events. That's not my bad, that's just my luck.
Old Feb 9, 2007 | 07:33 PM
  #47
Houstonderk's Avatar
My girl
Well I asked for pictures. lol
Old Feb 9, 2007 | 07:57 PM
  #48
I gotta say though, even without the rotors and e-shaft that thing was heavy. I've got mad respect for the Walmart broom,
.... hmm, now that I think about it, maybe she was taking pictures so she could show the insurance guy what happened that caused us to have to get a new sink, garbage disposal, cabinet and concrete slab replaced if that broom had cracked.
Old Feb 9, 2007 | 08:32 PM
  #49
NMJ87T2's Avatar
Are we there yet?
Chris, this is a great thread! I am glad to see the other builders lending their opinions as well.
Nolan
Old Feb 9, 2007 | 08:45 PM
  #50
staticguitar313's Avatar
R.I.P. Icemark
great thread, previous builder was probably cutting corners trying to make an extra buck, or just stupid . . .
