Rotary Drag Racing The place to post your racing stories and info
Proper Drag Suspension.......
Old Nov 8, 2006 | 04:03 PM
MichaelB145's Avatar
www.mancavecolorado.com
I am surprised you are getting 1.6's launching at that low of rpm. My car would bog hard doing that....When I drop it from 8500rpms, it does not hit rev limiter again as long as I did a 2nd gear burnout. If my burnout was not that good or it's really cold, then the tires spin and I will hit rev limiter again. My 60 ft times are about 1.55 - 1.63 but I don't have the power than the big boys have.
Old Nov 13, 2006 | 06:43 PM
twomucboost4u's Avatar
Always Under Construction
Just my input but between the last two post, difference might be the turbo?Maybe different injection? Michael, you might have to rev that high to biuld boost to get a decent launch, blitzboy maybe has a better turbo that spools quicker. I know to spool a large t4 journal or ball bearing you have to bounce it off the rev limiter to biuld boost, but blitzboy is dual ball bearing I think which I know will spool up off of reving lower which alows him to slip the clutch a little different. Anyways i could be way off but thats my guess.
Old Dec 17, 2006 | 12:33 PM
bkg's Avatar
bkg
Hey dan and Lupe have you guys considered running a powerglide or c4 tranny. I mean it would definately make your e.t's faster and wouldn't make so much of a forward to rear weight transition cuz it'll be constant boost no gear changing and no bogging.
I am by no means an expert at suspension but I just was wondering how that would work out.
Old Dec 19, 2006 | 08:33 AM
  #29
Dan Schechter's Avatar
JIGSAWRX7
Originally Posted by blitzboy
Question for the guys launching at High RPMs eg 8K, dont you hit the rev limiter straight away and then bounce off the limiter until you hit a decent road speed in 1st? or does the revs drop to an acceptable level and you hook up well?
Currently I launch at 4.5K and my 60fts are 1.6 to 1.7 I run Mickey Ts ET streets on FD stock rims at the rear with Petit launch kit,Mazdaspeed PPF and a diff brace with Tein HA coliovers on the softest setting at the rear
I launch at 7000 to 8000rpm depending on the track conditions, and yes, I do hit the rev limiter, but only for a split second until the tires grip and pull the rpm down to try and match the wheels, so it's not really anything to worry about.
Old Dec 19, 2006 | 08:36 AM
  #30
JIGSAWRX7
You're definitely on the right track, but unfortunately, I have to stick with a mazda tranny per NHRA's regulations. Otherwise....it would have been done already.
Old Dec 19, 2006 | 12:09 PM
  #31
Dan, when you do a 2nd gear burnout......how long do you do the burnout for? Do you have someone who measures the tempature with a laser? If so, what tempature do you want? Also, do you keep the rear suspension on the softest setting? How about the front?
Old Dec 19, 2006 | 12:51 PM
  #32
LUPE's Avatar
There is some information about shock setting etc. etc. etc. here.........
https://www.rx7club.com/showthread.p...2&page=1&pp=15
I think mickey thompson lists tire temp info on their website.
Old Dec 19, 2006 | 02:38 PM
  #33
bkg's Avatar
bkg
wow dan you and Lupe are really idols to me. You do things on a average persons budget and prove all the haters wrong, dan I've seen vids on your site and your call has the look of a car I'd catch at a car show or cruising on the street same as Lupes(I don't know if you do but they seem streetable). Big props to you all and thanks for the reply dan.
Old Dec 19, 2006 | 02:51 PM
  #34
Thanks Lupe, and I agree with bkg.....you guys are everything the rest of us hope to be some day!
Old Dec 19, 2006 | 02:54 PM
  #35
LUPE's Avatar
shoot, i'm just a squirrel trying to get a nut...........
My car sold over a month ago, I'm a nobody now....
Old Dec 19, 2006 | 07:16 PM
  #36
bkg's Avatar
bkg
So because of you Lupe we now know with tuning a freaking (almost) stock block can make 603hp with stock 2mm seals and your was running low 10's with like 1000+ miles on it. Man people like you and Dan make the 7 heads and rotorhead wannabe's(like me I know alot about roatry's but I don't have the erxperience you 2 have) No lie every time I get ion a debate about rx7's you are some of the examples I give about street driven performers.
But 1 thing I have to ask from curiosity and ignorance is how long will your engine last if maintained by a rotorhead.
Old Dec 30, 2007 | 09:24 PM
  #37
mario1386's Avatar
mazda mario
i have q's? i have a n/a s4 with stock ports wide open 5/6 ports a drop in filter and all emission tooken off ,suspenison wise i got ground control coilover sleeve on a stock struts front and rear i put an lsd in from a donor car and also a welded front differentail mount .So i go to test drive it and i decied to launch it from 7000rpm and not riding the clutch then boom the axle stub twisted and snap in two on the driver side is this common in n/a lsd ?
Old Dec 30, 2007 | 10:03 PM
  #38
Busted7's Avatar
Will work for horsepower
It is when you catch traction~!!! The axles are lighter and a 7'' ring gear.
Old Dec 31, 2007 | 01:53 PM
  #39
mario1386's Avatar
mazda mario
so what i got to do ? ride the clutch? or less rpm for launching?
Old Jan 14, 2008 | 07:31 AM
  #40
beefcake's Avatar
pushing s##t up hill
install bigger turbo rear end
Anyone on hear got hks drag coilovers, ive got some coming and id like to hear feedback , for a fc turbo of corse
Old Mar 13, 2008 | 03:34 PM
  #41
PDViper77's Avatar
HAHA V8
How much positive camber should I dial in the rear?
Old Sep 17, 2008 | 06:50 PM
  #42
willjs7's Avatar
3 and the hit for $100?
i would do a degree or so on aftermarket suspension.. maybe degree and 1/2, or even 2 on stock suspension due to travel. thats just IMO... i have mine at 0 right now and it works decent... this track season i will be messing with camber a bit.
Old May 16, 2009 | 10:27 PM
  #43
boostinfc3s's Avatar
would you recommend stance gr+ for drag? if so, how wouuld i set the stiffness
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
NickNac113
13
Oct 1, 2015 09:25 PM
rattlehead
Sep 25, 2015 10:55 PM
