OMP-Pre-mix mod Write-up
Old Apr 24, 2003 | 12:04 AM
marcus219's Avatar
FC Mobsta
Id check the lines to see if you can see oil moving..there usually all old and yellow, but you could still see oil moving through them I'd think. The S4 OMP's are pretty reliable units, but the lines get oil and brittle, any oil leaking?
Old Apr 24, 2003 | 12:50 PM
Newbie
sorry i didnt know people would get so pist off of a stupid thing....
Old Apr 24, 2003 | 01:02 PM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
I am not pissed off sorry but I did not see any relevance to my thread I thougt you just picked somewhere to post or did not know where you were posting.
Old Apr 24, 2003 | 10:04 PM
  #29
fstrnyou's Avatar
No oil leaks that I know of. I don't even know where to look to see the oil lines. So, I need to keep using MMO but only use more now? Or do you all have a favorite premix product?
Craig
Old Apr 24, 2003 | 10:37 PM
  #30
1987RX7guy's Avatar
I use costal. Use whatever you want as long as it is TCW3 then it is good. The OMP is on the front of the enigne it has four lines comming off of it. If you ever take off your UIM you will see the two oil injectors on the LIM and two on the block.
Old Apr 26, 2003 | 10:48 AM
  #31
JonEQuest's Avatar
Yes, that is my car
Would`nt it be better to just fix the OMP so it is working correctly?? Even if you modify it for more oil, either way it would be more convenient that adding oil at every fill up IMO.
John
Old Apr 26, 2003 | 12:26 PM
  #32
1987RX7guy's Avatar
John
The point is not to get more oil into the engine the point is that two stroke oil does not leave as much crap behind after it burns. The point of this mod is not convinience it is to increase the longevity of your engine. I am willing to spend an extra minute at the pump for my car I don't know about you.
Old Apr 26, 2003 | 01:36 PM
  #33
Pinfield357's Avatar
can some one point me in the way of a thread where they discuss the efficienty of 2cyle oil vs. regualar motor oil?
i guess that it will lube just as well since thats what it was made for im just very scepticle
sorry about the spelling i cant do it for ****
EDIT: just saw this on K2RD's web site
Elimination of the factory oil metering pump is reccommended only on race engines which REQUIRES pre-mixing of fuel.
why?
Old Apr 26, 2003 | 01:50 PM
  #34
1987RX7guy's Avatar
lol
that just means that normal people(us excluded) don't want to bother with putting the two stroke in every fill up. I have been runing pre-mix for a good while. The two stroke lubricates just fine and it burns cleaner leaving less carbon behind.
Old Apr 26, 2003 | 02:00 PM
  #35
so basically it just says that its for racers only because they dont think the everyday joe will bother with puting in premix a tthe station?
thanx RX7GUY i have always had respect for you and you always have tons of usefull information
Old Apr 26, 2003 | 02:08 PM
  #36
Amur_'s Avatar
Refined Valley Dude
Originally posted by RETed
Originally posted by Marcel Burkett
This isn't just about the time it takes , although I absolutely hate it (lazy ??) , but on the HURLEY site they also say that 99% of the premix is burnt without lubricating anything ,
I find this hard to believe. The (stock) oil injection was designed to lubricate these areas: 1) apex seal to rotor housing contact, 2) the apex seal to apex seal groove, 3) "secondary" seals such as the corner and side seals. Pre-mixing would be superior (over Hurley rotor oil jet mod) for #1. Hurley oil jet mod would be superior to pre-mixing for #2. #3 would be debatable. What is undeniable is that pre-mixes burn a lot cleaner than engine motor oil. Pre-mixes were designed to burn and leave a slight deposits for lubrication. This means all parts of the combustion chamber is affected during combustion. How can it not lubricate anything?
http://www.nmma.org/certification/p...ndex.asp?bhcp=1
Would carbon build up be a concern if I use synthetic oil and my water injection system ?
Synthetic oil? Yes. I've seen a motor using Amsoil 20W50 which left nasty deposits next to the spark plugs holes. These deposits would cause the apex seal to chatter over them (obvious chatter marks). This made me cringe - I do not recommend running synthetic oils if you are still running the stock oil injection.
, also I owned a TURBO 11 with the mechanical OMP injecting engine oil , I opened the engine after about two years and there was absolutely NO carbon !!, so what gives ?.
Beats the hell out of me? I've seen 30k miles 13BT engines come out with a slight layer of carbon (under 0.5mm) on the rotor faces all the time.
I've got a pre-mix FAQ on my site:
http://fc3s-pro.com/TECH/FAQ/premix.htm
-Ted
And look here for pics and commentary on the OMP.
https://www.rx7club.com/forum/showth...hreadid=146142
The OMP has poor coverage...
Old Apr 26, 2003 | 02:17 PM
  #37
1987RX7guy's Avatar
Yeah I am willing to pour it in and have yet to forget to. Thanks for the compliment but I am just another Rotor Head trying to help everyone out with their RX-7 I think of you all as brothers and don't really mind helping you all out.
Old Apr 26, 2003 | 10:07 PM
  #38
one more question
i still have to pass a sniffer test can i do that running premix?
Old Apr 26, 2003 | 10:26 PM
  #39
1987RX7guy's Avatar
Hmmmm
I would see no reason why you would not. It burns cleaner than regular oil so I would wager to say that it would help you pass emmisions. If not then move to TX where I live.
Old Apr 26, 2003 | 10:27 PM
  #40
Amur_'s Avatar
Refined Valley Dude
If you haven't disabled your OMP, then I don't know if you'd pass or not. You'd be burning a LOT of oil.
Old Apr 26, 2003 | 10:31 PM
  #41
thanx guys i will be removing my OMP thanks to this thread
Old Apr 26, 2003 | 10:33 PM
  #42
1987RX7guy's Avatar
Cool
If you need help just ask. I will be happy to help.
Old Apr 27, 2003 | 05:56 AM
  #43
mikeric's Avatar
FB=OS Giken LSD
Rotary Performance recommends using Amsoil 2 cycle engine oil, not Marvel Mystery oil as I had read on one of these threads. Just my two cents. They seem to know their business.
Old Apr 27, 2003 | 03:39 PM
  #44
im not exactly sure how the OMP works should i drain the oil first? when i take it off will it gush out oil?
Old Apr 27, 2003 | 04:01 PM
  #45
1987RX7guy's Avatar
No it will not gush out. I did not do an oil change whe nI went with pre-mix. a little oil came out but not much. I would have done the oil change at the time but I was short on cash and i had just done it like a week pior to that.
Old Apr 28, 2003 | 07:00 PM
  #46
fstrnyou's Avatar
Ok, back to Amsoil. Where do I get it and how much do I put in?
Old Apr 28, 2003 | 08:44 PM
  #47
would like to know as well (amsoil that is)
well and where can i get the RVT sealent and what exactly does it stand for or is that a brand name?
Old Apr 28, 2003 | 08:53 PM
  #48
Amur_'s Avatar
Refined Valley Dude
A list of all things Amsoil:
http://members.shaw.ca/pdktech/products.htm
RTV is just high-temperature silicone. RTV is the commonly-used name, not a particular brand.
Old Apr 28, 2003 | 09:43 PM
  #49
1987RX7guy's Avatar
permatex brand is good. I use the black stuff.
Old Apr 29, 2003 | 09:33 AM
  #50
ok thanx and i was looking at the amsoil stuff
the kind that is actually ment for 100:1 is really expesnsive
and they had another kind called injector oil that is basically the same so im gonna go with that
