One method of improving the rx-8 power!!!!!
Old Mar 19, 2008 | 02:49 PM
rotary8's Avatar
eccentric shafter
>>> "KIWI-RE" <kiwi-re@kiwi-re.com> 8/26/2004 4:37:40 PM >>>
The 4 rotor kit has the following:-
1:- Eccentric Shaft
2:- Front counter weight
3:- Rear counter weight
4:- 2 x Centre plates
5:- 2 x Stationary gears (modified)
6:- 2 x Stationary gear carriers
7:- 2 x Stationary gear external oiling mods
8:- Rear main nut
9:- 2 x eccentric shaft end caps
This kit is built with all new parts and also uses genuine Mazda parts.
The kit is $8500.00 (NZ) which at the moment (27/8/04) is approx US$5500
the price for this kit from Alec Bell was quoted to me in 2004 so it might be more you can always call him and find out but there is the list for anybody interested in doing a 4 rotor .
Old Mar 19, 2008 | 05:12 PM
overehttop's Avatar
What next?
just went to his site 03-19-08, and his new pricing is as follows;
4 Rotor Crank Kits $9,500.00 ($)
1:- Eccentric Shaft
8:- Rear main nut
This kit is built with all new parts and also uses genuine Mazda parts. This is a kit only and you will need an experienced engine builder to organize the rest of the parts and engineering and assemble of the 4 rotor engine.
currently 03-19-08 about $7,600.95 U.S. dollars
Old Mar 19, 2008 | 06:10 PM
crispeed's Avatar
'Tuna'
1:- Eccentric Shaft
8:- Rear main nut
That still does not cover some of the other custom stuff like tension bolts/studs, dowels and the list goes on!
Old Mar 19, 2008 | 06:16 PM
26B RX8's Avatar
ADD TO THAT $1400.00 SHIPPING,THE BOLTS AND SOME TIME!!!
Old Mar 19, 2008 | 09:57 PM
RoTaRyBoYz's Avatar
InsaneRotaries.com
^ hmmm with a name like 26b rx8 and with detailed knowlege of pricing I would take a guess and say you're involved in this project to also..
About a year ago I got a quote directly from Jeff Bruce, he's the machinist that kiwi gets his shafts from. Jeff's prices was diffinately cheaper than Alec and that was a complete kit with studs,machined plates etc... I have his email if anyone is Seriously interested in a kit..
Old Mar 20, 2008 | 01:02 AM
crispeed's Avatar
'Tuna'
Ok now that we all know the cost and where to purchase it from!
Back on topic the motor/tranny is in place or very close to where it's going to be. The placement is very good considering the length of the motor in that the front rotor housing is directly in alignment with the crossmember or just behind the centerline of the front wheels.
Pics comming soon!
Old Mar 20, 2008 | 03:19 AM
diabolical1's Avatar
... and you're in Miramar.
anyway, probably wasting my breath, but when you guys (Crispeed and 26B Rx8) get it together, please let me know. I will have completed my relocation to Miami by then(I should be moved in down there in 2 weeks), so I'd like to come over and see the tuning sessions.
Old Mar 20, 2008 | 04:07 AM
crispeed's Avatar
'Tuna'
New pics
Here are the latest pics.
Attached Thumbnails One method of improving the rx-8 power!!!!!-dsc06657-medium-.jpg   One method of improving the rx-8 power!!!!!-dsc06656-medium-.jpg   One method of improving the rx-8 power!!!!!-dsc06655-medium-.jpg   One method of improving the rx-8 power!!!!!-dsc06654-medium-.jpg
Old Mar 20, 2008 | 04:13 AM
crispeed's Avatar
'Tuna'
You're not wasting your breath. It's always cool to meet fellow rotor heads and make new/old freinds!
Old Mar 20, 2008 | 04:42 AM
RoTaRyBoYz's Avatar
InsaneRotaries.com
WOW that thing is long.... how far back was the tranny moved? How was the balance on the scale? My engine is so far back that I had to install a filter relocation kit because the pedistal is right next to my gas pedal and the front cover lines up in the original position... Cool project, so where you gonna put that turbo?
Old Mar 20, 2008 | 04:54 AM
crispeed's Avatar
'Tuna'
It's only like 4-6 inches forward of the 13B. The stick is perfect in that position also. It's moved back pretty far. The rx-8 tunnel is very forgiving in that department not to mention being dry sump helps a great deal.
The trubo and the header is not that tricky. Now I have no clue where the downpipe is going to end up.
I say rear mount the turbo!!!
Attached Thumbnails One method of improving the rx-8 power!!!!!-dsc06658-medium-.jpg
Old Mar 20, 2008 | 05:03 AM
RoTaRyBoYz's Avatar
InsaneRotaries.com
sounds good.... what are the plans for the other weak links, the tranny & diff? This project is a major undertaking with all the stock electronics, are you going to keep stock ECU for all that stuff?
Old Mar 20, 2008 | 05:33 AM
crispeed's Avatar
'Tuna'
Everything is going to function A/C, PS, ABS etc.
The tranny been taken care of allready although it's a 'X' model we'll see how far it goes. The rest of the drivetrain is going to be the last after it's almost completed.
Old Mar 20, 2008 | 08:45 AM
calculon's Avatar
On flats
Wow cris, I've never seen you divulge this much info. . . are the super secret squirrel days over? nah, can't be.
Old Mar 20, 2008 | 09:03 AM
classicauto's Avatar
Crash Auto?Fix Auto.
Sooo, do you get the power from the 3 oil filler necks???? I don't understand
Very nice! This thing will be a riot, love the sound of a 4 rotor!!
Old Mar 20, 2008 | 09:28 AM
rotorhead1983's Avatar
rotarysurgeonextraordinar
damn I just spooged in my pants.
Old Mar 20, 2008 | 12:07 PM
t-von's Avatar
Rotor Head Extreme
What kind of rack you guys gonna use? I can't imagine making all this work with the stock bulky eletric steering rack of the Rx8. It's only about 4" inches in front of the Renesis.
Old Mar 20, 2008 | 12:31 PM
crispeed's Avatar
'Tuna'
Yes it's pretty bulky but it does offer the simplest solution for PS.
The actual factory placement and setup makes it easier to be moved forward. It's as if Mazda had the intention of putting something way longer than a two rotor in there. The tie rod arms are actually forward of the rack so by moving it to the front you basically reverse the direction of the arms without having to modify it's length. Just have to get the bump steer correct. What is bump steer BTW!
Old Mar 20, 2008 | 08:33 PM
t-von's Avatar
Rotor Head Extreme
You know everytime we have an Rx8 in the air for an engine replacement, I'm always analizing stuff like this. I never even thought about moving the rack forward. I guess I'm slipping. . If yall can match the same angle when it's moved to the front, I don't see any reason for it to have bump steer.
Edit, then again the push angle is still different.
Old Mar 20, 2008 | 10:07 PM
  #45
crispeed's Avatar
'Tuna'
The push angle actually works out to be the same or better. On the Honda S-2000 when you do the 2jz transplant the rack ends up being in the same scenario and the power steering feel ia just like stock and you know that both the rx-8 and s2 use the same exact electric power rack.
Old Mar 20, 2008 | 11:14 PM
  #46
ultimatejay's Avatar
Sweet!
Old Mar 21, 2008 | 12:53 AM
  #47
Gorilla RE's Avatar
GorillaRaceEngineering.co
Hmmm.....
Old Mar 21, 2008 | 11:06 AM
  #48
t-von's Avatar
Rotor Head Extreme
Me too HMMMMMMM!!!!
Old Mar 21, 2008 | 08:25 PM
  #49
dj55b's Avatar
wow barely fits in there.
Old Mar 21, 2008 | 09:55 PM
  #50
That's what she said.
