How to: Pinion snubber install
Old Oct 6, 2009 | 10:51 PM
coxxoc's Avatar
Shooting for 500
Rationale:
I got tired of the clunking coming from the rear end of my car. Last year I replaced the front differential mount with the Mazda Comp version. My mount wasn't broken and it didn't help. What I saw was that since my car was lowered a lot, my rear suspension would hit the underbody at times. I think this is due the aftermarket one piece rear-link (camber link) design used to correct rear camber I have installed. It brings the sub-frame and front of the differential closer to the body. A pinion snubber is cheap at less than $10 dollars, and the job is pretty easy to do. There wasn't a good write up on the forum so here you go. The pictures are gathered from other posts and from the service manual.
Tools needed:
Hydraulic jack
Jack stands
17mm wrench
Various sockets 10mm, 17mm, 20mm (maybe it was 21mm?)
Ratchet
Torque wrench
Phillips head screwdriver
Drill and bits up to 3/8"
Parts needed:
Pinion snubber (came with locknut) http://www.summitracing.com/parts/ENS-9-9101G/
3/8" x 2" fender washers
Installation:
1. Remove the rear bins.
2. Drill a 3/8" hole in the dimpled area on the tunnel. The dimple is underneath the sound deadening mat in between the recessed bin areas.
3. Jack up the car enough to comfortably work under the diff area. Be safe and use jack stands. You'll need to use the jack to assist in adjusting snubber preload later; so you can't skip this.
4. Loosen the front mounts on the rear subframe. Only loosen the large nuts attaching the subframe to the mount bracket. Do not loosen mount bracket from the body. These mounts are on either side of the body just in front of the rear wheel well.
5. Remove the lower bolt from the rear link.
6. Install the pinion snubber in the hole you drilled earlier. It should be visible above the front differential mount area right in between the parking brake cables. Pull down on the front of the differential housing to create clearance to install the snubber.
7. Reinstall the bottom bolt in the sub-link.
8. Jack up the subframe to its normal position.
9. Check to make sure that your snubber is slightly preloaded. If there is a gap, lower the subframe, the revert back to step 5. Add fender washers in between the snubber and bottom of the body to space it out. I added two fender 3/8" x 2" fender washers to mine to get the preload just where I wanted.
10. Tighten up the pinion snubber. I used another fender washer up top as well to tighten on a flat surface.
11. Tighten the subframe nuts to 74-87 ft/lbs.
12. Tighten the sub-link nut to 54-69 ft/lbs.
13. Install the rear bins.
14. Lower the car off of the jacks.
14. Go test drive and enjoy your non-wheel hopping, non-clunking rear end!
Josh
Attached Thumbnails How to: Pinion snubber install-dimple.jpg   How to: Pinion snubber install-subframemount.jpg   How to: Pinion snubber install-sublink.jpg
Old Oct 6, 2009 | 11:49 PM
KhanArtisT's Avatar
Former FC enthusiast
Can you explain why the subframe has to be lowered? On my install I just jacked the car up and installed the snubber b/w the diff and chassis and adjusted preload as necessary.
Also remember that most advance and autozone stores should carry the pinion snubber! Its made by energy suspension and its called a bump stop or something.
Old Oct 7, 2009 | 12:36 AM
dkwasherexd's Avatar
Garage Life
great writeup! I have gone through like 3 diff mounts and 2 rear subframes. If I dont break a diff mount, the subframes diff mount will break instead -_- Getting sick of going under and replacing the subframe and diff over and over... I shall do this mod haha
Old Oct 7, 2009 | 06:22 AM
coxxoc's Avatar
Shooting for 500
I had to loosen the subframe for clearance. I couldn't fit my hands up there without loosening and pulling subframe and front of the differential down some.
Old Oct 7, 2009 | 06:59 AM
arghx's Avatar
rotorhead
Good writeup. Maybe I should do this to my car, I still have stock diff mount and I'm worried about breaking something. So can this install be done without loosening the subframe bolts then, depending on how much the car has been lowered? Also, did you remove your exhaust for this?
Old Oct 7, 2009 | 11:26 AM
MaczPayne's Avatar
Mac Attack
Finally, a write up! This mod is very common among v8 FC owners, and it works!
Pinion snubber + MMR diff bushings + comp. front mount = Bulletproof
My sub-link camber adjuster is practically useless now since the diff is so firmly mounted and "snubbed".
It's possible to install this with your exhaust on, but the job is just so much simpler with it out of the way.
Old Oct 7, 2009 | 02:32 PM
coxxoc's Avatar
Shooting for 500
I did it with the exhaust on. My car is very low and probably directly attributed to my need to lower the subframe. Only part of the sidewall is visible on my rear tires. You can't really tell how low it is because I have a stock body.
Old Oct 7, 2009 | 06:35 PM
Hypertek's Avatar
Slowpoke
i did mine without touching the subframe. What helps is using a dremel to make a "slot" in the stub for the bumpstop so when you have it in the hole, from the inside, you can use a flathead screwdriver to keep the stud from spinning while you tighten the bolt.
Old Oct 7, 2009 | 07:06 PM
arghx's Avatar
rotorhead
Could you elaborate a little further? Maybe post a crude MS Paint diagram or something?
Old Oct 7, 2009 | 07:15 PM
ifryrice's Avatar
Sequentially broken
I believe he's saying to dremel a channel in the threaded stud coming out of the snubber. When you have it in the hole you drilled while tightening you can use a flat-head in the channel to keep it from rotating while tightening the nut.
Old Oct 26, 2009 | 01:04 AM
hiroichi1515's Avatar
Since the pinion snubber goes over the little block on the front diff mount, it should be possible for me to install that with a broken diff mount (Rubber separated from mount) or do I have to replace the diff mount before I put that on?
Old Oct 26, 2009 | 01:23 AM
SmogSUX's Avatar
No money. No love.
I had Rotary Evolution install mine..WORLD of difference. Sliding, drag racing, and even just cornering. Pretty much got rid of ALL my wheel hop. Best mod EVAR
Old Oct 26, 2009 | 02:22 AM
VividMP5's Avatar
Nice! This is going to be on the list of things to do!
Old Oct 26, 2009 | 12:12 PM
MaczPayne's Avatar
Mac Attack
If your rear diff bushings are worn out, be sure to replace those too.
Old Oct 26, 2009 | 01:24 PM
KhanArtisT's Avatar
Yup, thats part of the reason why this mod is so popular. I'm running mine with a broken front diff mount (but new rear mounts) and it feels waaay better. Not perfect though, you still hear a light thud when shifting but way better than a clunk.
Old Oct 26, 2009 | 02:16 PM
fc3schick87's Avatar
Rotary Addiction
good post. i use this , but remember if your driving hard u may bend the metal under the bins like i did
Old Oct 27, 2009 | 02:28 PM
lonewolfrx's Avatar
nice post.. im planning on doing this when i have free time
Old Oct 27, 2009 | 03:42 PM
staticguitar313's Avatar
R.I.P. Icemark
good post, did this myself about 2 years ago when i still had my FC, saved me quite a bit of agony
Old Nov 9, 2009 | 12:42 AM
nightridaz777's Avatar
Welded Ass Hell
yeah just did this mod myself. feels wayy better. took away all wheel hop.
Old Nov 9, 2009 | 08:12 AM
arghx's Avatar
rotorhead
I'm having trouble motivating myself to get started on this. I just did a bunch of work to my interior and I don't want to pull those storage bins out and risk braking more plastic.
Old Nov 9, 2009 | 09:36 AM
solareon's Avatar
removing the storage bins won't break any plastic. it's all screws and no snap fit crap
Old Nov 9, 2009 | 07:27 PM
tigerbite's Avatar
I am going to do this mod soon. What is the estimated time to do this mod? Maybe 3 hours?
Old Nov 9, 2009 | 09:58 PM
ForsakenRX7's Avatar
zoom zoom go boom
If that. With everything laid out it should be a quick job. This is a necessary mod though.
Old Nov 9, 2009 | 10:23 PM
turboIIrotary's Avatar
is this the same on a vert?
Old Nov 10, 2009 | 12:21 AM
Welded Ass Hell
took me less than a hour to do the mod.(most of the time it was finding the right size spacer)
