Wide body, side skirt, ground effect, fiberglass enchancement.
Old Nov 21, 2008 | 01:44 PM
drifted's Avatar
Hello. It is just about a time to document the next process in the game. This one will include enhancement of Mariah body kit. Per my opinion I've always thought that this amazing kit was under designed, missing a crucial element which was a connection of the flairs. Without these car look fragile, and not balanced. I am deciding to alter it a bit. I will add "volume" to the body by connecting the flares with a side skirt. Also it has a very important practical value for me. Since i will panel a whole bttom of the car w/ plain panel for aerodynamics, as well to force it down at movement, this extension will allow me to create mounting points for the panel.
This is a basic brainstorming done off a foam core and hot glue gun, as discovered, the best materials to run such of analysis. This can also be used as a template for positive glassing. If doing such, remember to work "smaller", allowing for fiberglass and bondo build up. This process will take weeks before i lay fiber, and will be much longer that last: "3 beam lenses project" (https://www.rx7club.com/1st-generation-specific-1979-1985-18/3-beam-light-sleepy-eye-hd-headlight-conversion-800210/).
Also i am at preliminary stage, where i am fighting with curvilinear vs rigidity/geometric lines. I don't want to go too soft, but there is a limit to geometric shapes for this body. Therefore what you see is just a stage, but i am open to comments.
Thank You. Bartok
Old Nov 21, 2008 | 02:39 PM
DivinDriver's Avatar
1st-Class Engine Janitor
Any eventual girlfriend you may acquire will not thank you for making it nearly impossible for her to get out of the car without flashing her panties at the valet.
Old Nov 21, 2008 | 02:50 PM
rotary84's Avatar
interesting
Old Nov 21, 2008 | 04:02 PM
rx-7ames's Avatar
However, we will thank you.
Old Nov 21, 2008 | 04:07 PM
Jimbo II's Avatar
Rotating
Now its gonna come down to paint colours to make it work, black is good for these widebody styles...
Old Nov 21, 2008 | 04:57 PM
Well, that goes without saying.
Old Nov 21, 2008 | 08:32 PM
jones75240's Avatar
I say Nordic Green thats used on the 04-05 RX-8's Would look good with those rims too. Is a very dark green with awesome shimmer to it. At night it almost looks black.
Old Nov 21, 2008 | 11:48 PM
BlackWorksInc's Avatar
Wrkn Toyota, Rootn Wankel
Yeah, a Nordic Green would look awesome on a widebody...
Old Nov 22, 2008 | 12:41 AM
Directfreak's Avatar
I am a Jeeper Now.
1) I don't believe that's a true Mariah Kit.
2) Mariah sells a rocker panel for it's Mode 4 (non-widebody) kit.
I bought the rocker panels to integrate with my Mode 1, eventually when I can afford to do it again.
Old Nov 22, 2008 | 10:03 AM
drifted's Avatar
replacing crooked section of the curve
puma
you can shave foam core to transition volume of the add on
diamond plate?
geometrically, the focal element will be the tip of the skirt. Like a wing, slim, but rigid at the very tip
Old Nov 22, 2008 | 12:04 PM
rx-7ames's Avatar
Originally Posted by drifted
diamond plate?
I think diamond plate would scream redneck. I don't think that's the look you are trying to go for.
Old Nov 22, 2008 | 12:13 PM
I am a Jeeper Now.
drifted's Avatar
or polished aluminum. this element will be repeated few locations, sides of the lights and the bumper (rubber replacement) tip of the skirt wing, handle to the door and the kick plate. it will not be an application, but independent section possibly tilted an angle to the wing. it will be classy!
Old Nov 22, 2008 | 12:16 PM
drifted's Avatar
Originally Posted by Directfreak
xxx
nice finishing job!!
i've seen couple of these straight skirts, but i want something with more "kick"...more angles and energy and the feel like the wind is being captured, not only transfered
Old Nov 22, 2008 | 12:36 PM
Kerebrus's Avatar
That has to be the sexiest thing to grace this Earth, ever.
Old Nov 26, 2008 | 10:53 PM
trochoid's Avatar
Old Fart Young at Heart
I have the same kit, and it's not a Mariah product. Mine was made by the infamous CP Racing. Same kit is now offered by Black Dragon, made in Ohio. Both of which I believe are knockoffs of the old Pacifica kit.
I considered doing something similar to my rockers, until I cracked my lower shin on the lower front lip of the rear fender, ouchie.
My widebody is in the following link.
https://www.rx7club.com/build-threads-293/unvieling-12a-bp-widebody-462184/
Old Nov 27, 2008 | 12:18 PM
drifted's Avatar
yeah, after directfreak comment i have realized it is not mariah. i knew it was fairly similar to red dragon, but for a long time i was under impression that mariah and red dragon is the same thing. thanx for bringing some history to my knowledge, and thanx for the link- nice job. i see you've had the same dilemma with the wheels size. also i am considering narrowing the front flares a bit, or maybe just the first curve of the fenders, but i have to wait until skirt is done so i can see overall. are you having any more body modifications coming up? good luck
ps: perhaps someone could edit the title, and put panama sport instead of mariah as i like the name a lot
Old Nov 28, 2008 | 07:15 AM
drifted's Avatar
hello.
now the other side
transfer the curve, here done on this corrugated sheet of plastic. its transparent, but hollow- easy to cut
i run short on the material on the tip of the wing, so just added a bit. Also look: about 3/8 inch recesses along the side, as well little triangle piece is set in- thats for a build up of material (epoxy and fiber)
also as you look on the bottom of the triangle piece, the foam core is notched, that's the trick to gain larger angles than material flexibility.
thank you
Old Nov 28, 2008 | 01:45 PM
openshot's Avatar
Wankel Me This!!
that looks nice low
Old Nov 28, 2008 | 06:54 PM
Whisper's Avatar
With this little ground clearance how do people get the jack under there? Seems like it'd be a PITA.
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
