Didnt leave well enough alone... lots of starting issues now
Old Aug 18, 2007 | 08:54 PM
Frogblender's Avatar
So I had the car running great, something that hasn't happened in a while, but the idle still didn't satisfy me. I have a friend rev the engine while I pour a the rest of the Seafoam I saved equally through all four carb barrels (I had like 1/16 of a can left.) It bogs but my friend manages to keep it up until it finally just gives up and dies. We tried starting it for about half an hour but all we get is exhaust backfire, with intermittent puffs of smoke popping out of the carburetor (air cleaner assembly was left open). So we remove the plugs (which smell like raw gas, especially at the front rotor), clean them, disconnect the ignitors on the sidewall and crank the car to unflood it, and white smoke pours out of the engine bay; a good sign. We slap the plugs back in and this time the car tries to crank and even starts for a couple seconds, but the tachometer doesn't respond. Again, we pull the plugs and this time we clean them on a bench grinder with a wire brush, and I spray a bit of carb cleaner into the gas tank. I start cranking the car without the plugs to deflood it again but this time after a bit of cranking and no smoke it stops dead in it's tracks. Now trying to start it, all we get is a click and no response (no engine activity). I assume we've blown something but I used a lot of mixed advice off board searches, which obviously got me into trouble. Any help is appreciated at this point, we're desperate and we want this thing to run before tonight otherwise we won't be able to sleep at all. I guess we'll learn now not to fix **** that ain't broken
Old Aug 18, 2007 | 09:43 PM
Kentetsu's Avatar
1. Put seafoam into the gas tank, not down the carb. More likely to cause problems than to fix them that way.
2. You flooded it.
3. Plug your trailing ignitor back in properly. That's why the tach isn't moving any more.
4. Charge the battery back up overnight on a good charger. If you don't have one, some parts stores will do it for you for free.
5. Now, this may sound funny since you flooded it while using the seafoam, but seafoam is what's going to get you started again. Make sure the plugs are clean, then pour 2 caps full down the small (primary) barrels of the carb. Pump the gas two times, then crank it over and it will start. BUT DON'T TRY THIS UNTIL YOU HAVE A FULLY CHARGED BATTERY!. There are many ways to deflood a rotary, but I have found that the seafoam works best, and doesn't result in fouled plugs like most other methods.
Good luck man...
Old Aug 18, 2007 | 09:46 PM
ray green's Avatar
8647
OK, this all sounds familiar. First of all, your battery is probably dead. Hook up a charger to it for a good long time. Second, it sounds like your trailing ignitor got disconnected somehow or is bad that's why the tach doesn't work. But it also cuts off the fuel pump, which means the car won't start because it's not getting any gas (how ironic).
To find out if this is the case, remove your fuel line into the carb and crank it (when you get the battery charged) you won't see fuel. No fuel means fix the ignitor, or if you want a quick way out, just hot wire the fuel pump with a wire running from the hot wire to the rear hatch light down to the pump, under the driver's side storage compartment.
Now you have also made a holy mess out of the chambers and your spark plugs with all that sea foam and stuff, so you need to clean that up. Once you have the battery charged up and the plugs out, spin it over to get out the misty stuff. Then put about 20 mls of automatic transmission fluid into the two carb primaries and turn it over again. The mist should be getting oily, without any gas or sea foam smell.
Let it set, spin it some more and make sure things are nice and clean in there, with a light oil coating to help out the apex seals.
Those plugs need to get real cleaned up, a wire wheel on a grinder does a good job and lots of compressed air to get out all that sea foam out. You might touch them up with a little sand paper and alcohol at the end.
Now put in the plugs, crank it over without any gas, then hit the peddle and pray. If it doesn't work, you may need to tow it down the road a bit.
Always worked for me.
Ray
I see since posting this that Ken's been there done that too.
Old Aug 18, 2007 | 10:07 PM
Just a comment on the battery, it was bought new last month (Motomaster, fully charged and warranted) so I don't think there should be a problem but I can throw a (Motomaster!) charger on it overnight. I'll try getting the ignitor caps reseated too, I didn't touch anything in the engine bay after finding it didnt crank. We achieved a ******* 900rpm idle by fixing up the major vacuum leak with a t-joint and some extra hose in place of the original hose's bend, and this is a direct result of me and my friend saying "well it runs fine and we shouldn't touch it but maybe we should find a way to make it better." Guess you could just call us bored idiots
EDIT: Oh, and the other 15/16 of the Seafoam can was funnelled into the gas tank two days prior. I'll be stocking up on it tomorrow.
Old Aug 19, 2007 | 12:39 PM
Jeff20B's Avatar
Lapping = Fapping
tow or push
Old Aug 19, 2007 | 12:56 PM
Kentetsu's Avatar
Even a brand new batter can get run down by continuous attempts to start. Get a good charge on her, so you don't end up flooding it again.
Or, like Jeff mentioned, you can push or tow it...
Old Aug 19, 2007 | 01:43 PM
13B SA22's Avatar
Hey Iam having the same problem with my car! Iam not trying to hi jack the thread but what is seafoam? Where can I get some?
Old Aug 19, 2007 | 01:51 PM
I get mine at NAPA. Any good auto store should stock it, just ask politely and you shall receive
Old Aug 21, 2007 | 01:25 PM
I took the warranted battery to Crappy Tire today. The woman at the counter said her battery tester was reading the battery as overloaded (13V). I had left it on the charger for about 24 hours because the unit itself didnt show a change of status. The car, however, has a different story. The voltmeter on the dash reads just under 12V and when I try to crank it, it plummets to just over 8 and the dash lights dim to the point of being off. I put nice new terminals on the battery cables in addition to cleaning the terminals. I also cleared out all the ignition cabling and related connections with contact cleaner. Any idea as to what's happening? How do I do a safe spark test (the Haynes was a bit vague)?
Old Aug 21, 2007 | 02:15 PM
I think it's seized... the main pulley is frozen in place. I'm assuming this is the large one at bottom, dead-center where the rotor shaft would be (if anyone has a pic they can point it out in that would help). I'm trying to turn it but no dice. This is really getting depressing as it was my fault... anything I should try to do before I do the ATF treatment? I'm afraid I popped an apex seal or killed a starter with all the cranking I did after the fact. Then again, it could still be the battery, but I won't be sure until I know which is the main pulley.
Old Aug 21, 2007 | 03:11 PM
Kentetsu's Avatar
Damn, it sounds like she's locked up alright. You can try turning the main pulley (sounds like you've got the right one) back and forth a bit to work it loose. Maybe pull the plugs out, and shoot some seafoam in there and let it sit for a while. Forget about using ATF. Good luck man...
Old Aug 21, 2007 | 09:14 PM
I called the previous owner (the owner before the skeezeball I had bought the car from). He said he offloaded the car because he was told there was coolant leaking into the engine as well as an oil leak, and the apex seals were wearing out. I'm afraid I have now pushed the engine to it's breaking point unaware of the consequences. All I can do now is try to assess whether it has more value as a rebuild or as a parts car, as I don't even have a penny to my name. Goodbye, initial expectations I'm so depressed right now it isn't even funny.
Old Aug 21, 2007 | 09:35 PM
ray green's Avatar
8647
Man that's a tough one. Take a deep breath and go back at it tomorrow. The main pulley it the big one at the bottom with about four grooves in it. The outer ones are for your accessories, AC and air pump. The inner ones drive the alternator and water pump.
Down in the center is a recessed nut, about 17 mm. Get a socket on that, put on the ratchet and try to work it lose. You can get a bit more leverage if you have a short piece of scedule 40 PVC tube you can slip over the handle of the ratchet. Work it back and forth to see if you can get it turning again. The ATF is a light oil that will provide some lubrication for this process, you can clear this out once you get it turning.
The good news is that's one sweeet looking 7.
Good luck!
Ray
Old Aug 22, 2007 | 07:06 AM
H4Inf's Avatar
Absolutely! just take a day off then get back to it, it looks straight and clean in the pic, so worth following on with i reckon. You've got everyone on the forum here to help you through any problems that come up as well..
All the best!
Paul.
Old Aug 22, 2007 | 02:47 PM
Any strategies for getting that rad fan off? I can't unscrew the four bolts to disassemble it because the whole assembly keeps rotating. I tried a couple of times to access the main pulley bolt with the fan attached and all I have to show for it is skinned knuckles
Old Aug 22, 2007 | 03:25 PM
Rogue_Wulff's Avatar
Too old to act my age
Large slip-joint pliers, with a rag around the pully to prevent scarring. Hold on the front part of the pulley, or the fan clutch adapter.
Old Aug 22, 2007 | 04:24 PM
Kentetsu's Avatar
I just take a screwdriver, and place it behind the mount so that it crosses between two of the bolts. Use that as a lever to keep the assembly from rotating...
Old Aug 23, 2007 | 12:34 AM
Jeff20B's Avatar
Lapping = Fapping
I use two 10mm wrenches. One to hold one bolt in tighten-mode, which holds the fan and keeps it from rotating. The other to loosen one of the other bolts. I work my way all the way around. Once each bolt is broken loose, it snugs up again during the process described above, but is much easier to unsug them the second time around.
I've tried the screwdriver method but there is a chance of slipping. With access to two wrenches, it's made life better.
Old Aug 23, 2007 | 09:39 AM
IanS's Avatar
Ricer
Word, 2 wrenches is the way to go.
Old Aug 23, 2007 | 04:46 PM
With the two wrench method how do I get leverage for the last bolt? I'll likely need replacement bolts down the road as these ones are old and got pretty stripped when I worked them out.
Old Aug 23, 2007 | 10:59 PM
Rx7UnitOne's Avatar
Beginner RotorHead
While most likely not the correct way of doing it, I grab the belts and squeeze a little on them. That freezes the pulley and I can take off the bolt. It works for tightening too.
Old Aug 23, 2007 | 11:10 PM
mar3's Avatar
Administrator
Put the belts back on and tighten it all up. Observe the rotation of the pulley and then stick a large screwdriver into the slot where the belt is going into the slot of the pulley as you try to loosen the last bolt. The pulley will stop rotating at some point and then you'll be able to get that last screw off...make sure the other screws are still on but one turn less than finger tight...or expect to lose more skin and blood...
Old Aug 23, 2007 | 11:36 PM
Jeff20B's Avatar
Lapping = Fapping
That screwdriver in the sheave method is not a good idea if you're building a show car engine. Too easy to scratch the paint.
Old Aug 24, 2007 | 10:00 AM
I might end up replacing the entire pulley system anyways and sacrifice the A/C (it has no use to me, real air conditioning = windows and sunroof open.)
Old Aug 24, 2007 | 01:08 PM
I got the fan shroud and fan assembly off, that belt-pinching method worked magically. I might do a little write-up for the archive if it's something needed, any other noobs interested? Now, I have full access to that bolt (it's 19mm), which way should I be turning assuming I'm working at it from the driver's side; towards me or away from me? Or do I just try my best to loosen it both ways?
