NW RX-7 Forum Serving Washington, Oregon, Idaho and Alaska members
Water leaks from behind dash WTF?
Old Jul 24, 2006 | 03:28 PM
1987_Gxl's Avatar
ALLyourRX7areBELONGtoUS
running AC iin this heat while driving has become a priority
i noticed some water leaking from behind/below the dash onto the passenger side floor board, the water was cold, and the black box under the dash was also cold.
there was not alot of water, but more would run out around a lefthand turn.
I have a 91 NA
AC is cold
heat is hot
someone seems to think my heater core may have a leak
can anyone confirm or deny or provide more options, i don't want to rip the dash out to replace the heater core :P
Old Jul 24, 2006 | 03:47 PM
Atkins Dan's Avatar
Former Site Sponsor
look to see if your A\C drain is hook up that should be a small hose going throu the firewall... I dont think it is your heater core because if it was the water would be hot and not cold..
Dan
Old Jul 24, 2006 | 03:57 PM
1987_Gxl's Avatar
thanks
Old Jul 24, 2006 | 04:01 PM
Atkins Dan's Avatar
Former Site Sponsor
your welcome...
Dan
Old Jul 24, 2006 | 05:25 PM
1987_Gxl's Avatar
hmm well the drain tube appears to be attached and running through the firewall just fan, ran AC on way home today, but no leaks.
granted it started leaking after a long amount of time this weekend
Old Jul 24, 2006 | 06:22 PM
KarynKathryn's Avatar
glows in the dark
Check your AC drain line, it sounds like your drain line is plugged or partially plugged and not allowing the condensation to drain out of the housing.
Jeff20B
73
Sep 16, 2018 07:16 PM
msilvia
15
Sep 11, 2015 12:13 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
gabescanlon
Sep 5, 2015 12:04 AM
