Emissions update (still failing, help?)
Old Mar 1, 2004 | 07:21 PM
ddub's Avatar
i am legendary
Question Emissions update (still failing, help?)
Well, here's another thread about my emissions... Some of you know the trouble i've been going through with my last two threads about this, but since then I found a blockoff plate that was installed for the check valve and split air selenoid valve that was probably making it worse. Anyways, i took that off and plugged 2 vac nipples that would (i was told) cause air to be pumped into the cat constantly rather than just at cruise. Along with that I also got an S-AFC and in lo-throttle for the test i was running -16 at 1000rpm, -20 at 2000 to 4000 rpm. Last test I failed both idle tests and passed both cruise. But the test i took today I was passing the CO% at idle but not the HC
Last test idle
HC - 1346 CO% - 5.4
This test idle
HC - 399 CO% - 0.15
Limit for idle
HC - 220 CO% - 1.2
So I did make an incredible improvement on the idle. I even made a good improvement on the cruise with 0.02 CO% this time and 69 HC where limit is 1.1% and 160 HC. So what's left to try? Ive tried to fix everything and I'm startin to get stuck. Ive heard that some people say to change the spark plugs every oil change and its been about 1.5 oil changes since I changed mine, but I dont think this could account for all of it, right? What exactly are Hydrocarbons (HC) and where do they come from/what creates or blocks them? One last note, I am running premix now, but from the threads I read about premix and emissions people didnt think it was that big of a deal, is that whats wrong? Thanks for any help or input you all can give me.
Old Mar 1, 2004 | 07:29 PM
PHATFC3S's Avatar
kichiku beihei
i dont know what else to tell you about what to fix or what raises or lowers your hc. i know that alot of people around here fall back on denatured alcohol if they cant get theyre car to pass emissions. and once they run the alcohol through it passes no problem
Old Mar 1, 2004 | 07:45 PM
ddub's Avatar
i am legendary
yah ive been told that but im not sure i wanna run alcohol through my engine, i mean, it cant be the best thing for it... thats why im trying to do it with things working correctly
Old Mar 1, 2004 | 07:51 PM
vrooom305's Avatar
what about your headers? if that was taken care of sorry I didn't see your past thread about emissions...
Old Mar 1, 2004 | 07:55 PM
ddub's Avatar
i am legendary
could that really effect emissions that much? plus i dont have the stock exhaust manifold and my cat doesnt sit in the stock place because of the header, so the exhaust manifold/downpipe wouldnt match up
gsracer's Avatar
EIT
what ratio pre mix are you running
Old Mar 1, 2004 | 07:56 PM
ddub's Avatar
i am legendary
1 ounce per 1 gallon
Old Mar 1, 2004 | 07:58 PM
gsracer's Avatar
EIT
have you tried adjusting the idle a/f mixture with the variable resistor on the passenger side of the engine bay by the shock tower?
Old Mar 1, 2004 | 08:00 PM
ddub's Avatar
i am legendary
yep, i turned it to as far lean as it would turn
Old Mar 1, 2004 | 08:12 PM
gsracer's Avatar
EIT
the t2 fuel pump might have bumped up the fuel pressure, making you run leaner. Have you ever had the car on a wideband with the safc?
When I had the walbro on my otherwise stock fuel system and tried to pass emissions, my Hydrocarbons were tripple the limit, something like 800. When I put my stock fuel pump back on I passed easily.
Old Mar 1, 2004 | 08:17 PM
ddub's Avatar
i am legendary
hmmm really... i was wondering about that, but when i asked before i was told that the TII fuel pump wouldnt make it that much worse i guess i can try that too, i just hate changing the fuel pump, oh well
Old Mar 1, 2004 | 08:21 PM
vrooom305's Avatar
where is the fuel pump anyway?
Old Mar 1, 2004 | 08:22 PM
cat and alcohol
Old Mar 1, 2004 | 08:23 PM
ddub's Avatar
i am legendary
under the hatch carpet/mat
Old Mar 1, 2004 | 08:59 PM
casio's Avatar
casio isn't here.
forum lag..
Old Mar 1, 2004 | 09:03 PM
casio's Avatar
casio isn't here.
HCs are HydroCarbons (basically your gas/fuel).
okay, i'm going to do some visual thinking and see what all i can put together:
Last test idle
HC - 1346 CO% - 5.4 <<well that's horrible
This test idle
HC - 399 CO% - 0.15 <<nice improvement
Limit for idle
HC - 220 CO% - 1.2
HC is your fuel + Oxygen (and other gasses; you dont even mention NOx, another result of combustion, nor CO2).
do you by any chance have your CO2 or NOx numbers?
honestly, to me (a non-professional), it appears you're merely still running rich. yes, there are ways to pass emissions, but sometimes youre cheating yourself. this, of course, isnt always true, but here i would think it is. your system seems to be functioning properly, how else would you have such a great (low) CO%? you need to get rid of those HCs (which is extra fuel). i think you're still running rich at idle. if i'm wrong, i hope someone could explain why.
Old Mar 1, 2004 | 09:08 PM
ddub's Avatar
i am legendary
no CO2 or NOx. I have a CO+CO2 % is that what you mean? I also have an O2% but neither of those seem to matter for passing the test, because they say N/A for results
Old Mar 1, 2004 | 09:14 PM
casio's Avatar
casio isn't here.
weird. in DFW, my test gave the results i believe. its been about a year and a half since i tested it.
NOx is a result of temperature, and HCs affect temp (run richer = lower temps, leaner = hotter) so there's a correlation. CO2 also is a clue to how well your cat is working. and O2 shows how rich/lean you are as well compared with stoich (if i remember right).
Old Mar 1, 2004 | 10:39 PM
RXSevenSymphonies's Avatar
Turbo Swamp Thing
This doesn't help much for this thread, but I'm just gonna post this neato pic for future use.
Old Mar 1, 2004 | 11:52 PM
casio's Avatar
casio isn't here.
haha, everything i've been saying in the form of a picture! that is pretty cool, where's it from? i'm sure there's more info where that came from.
Old Mar 2, 2004 | 12:02 AM
Amur_'s Avatar
Refined Valley Dude
I've done it (methyl hydrate in my case,) as have many others. It won't hurt your motor. If you put a high ratio of it in, your 7 will idle like **** and be underpowered for the drive in to the test, but that's it.
Your premix ratio could be knocked down a bit. Try 140:1 (13oz / full tank) at your next fill up, which is what I run. Every bit helps, right?
Old Mar 2, 2004 | 12:55 AM
ddub's Avatar
i am legendary
Since I'm so close to passing, would running lower premix in combination with alcohol and a full tank help me get to passing? Like putting in the alcohol with everything else?
Old Mar 2, 2004 | 01:05 AM
Turbo Swamp Thing
Its from my autotech book, theres about 60 pages in it devoted to how emissions work and emissions troubleshooting and repair.
Old Mar 2, 2004 | 01:07 AM
gsracer's Avatar
EIT
why not try leaning out your idle with the safc?
Old Mar 2, 2004 | 01:09 AM
casio's Avatar
casio isn't here.
i'm not sure how premix hurts. i dont know the composition of 2-stroke (if its an HC or not). and alcohol wont hurt your engine. dont know what you meant by that. it takes more alcohol to make the same amount of power and i believe to meet the same stoich number (i need a graph of all these facts). but alcohol runs cooler and can make more power in the end (like nitro- which makes ~twice the power as gasoline but requires 4 times the amount to do so). so i would think this slight bit of alcohol would run cooler (less NOx) and leaner (less HCs). thats just my guess.
problem with alcohol is that it has a tendancy to attract moisture which eats through parts of your fuel system. as far as engines, i think its quite a pleasant chemical. i did very little research and found how difficult it is to run alcohol (as the main fuel) and left the idea at that.
