Removing my ABS
Old Aug 4, 2003 | 11:53 PM
Rx72Die4's Avatar
Removing my ABS
can someone tell me of a website i can order these from?
Front-Right Non-ABS Pipe FB01-45-280E
Front-Left Non-ABS Pipe FB01-45-320
Rear Non-ABS Pipe FB01-45-360C
Old Aug 5, 2003 | 02:32 PM
Rx72Die4's Avatar
nobody knows?
Old Aug 5, 2003 | 03:42 PM
jimmyv13's Avatar
Round&Round not Up&Down
mazda dealer
Old Aug 5, 2003 | 04:02 PM
Bruce's Avatar
Are you trying to get the brake lines for the non abs system? Why not just rebend the lines or get fittings to hook lines up to the proportioning valve? What proportioning valve are you getting? You could call summit and get the wilwood proportioning valve which is also adjustable.
Old Aug 5, 2003 | 07:21 PM
dr0x's Avatar
pei > caek
Because the lines come to a total of like 40$ and is way way way easier than bending them. Lots of people that bend them usually have a leak.
Old Aug 5, 2003 | 11:14 PM
Carl Byck's Avatar
Mad Man
I'd be interested in you wheel speed sensors, I want to do a Racelogic TC system, but I do not have ABS. Carl
Old Aug 5, 2003 | 11:18 PM
Rx72Die4's Avatar
ill try the mazda dealership on thurs then, im pretty sure i can use the proportioning valve i have, they are interchangeable right?
Old Aug 6, 2003 | 01:52 AM
hIGGI's Avatar
dont forget ABS and non-ABS master brake cylinders are different....
i did ABS removal few weeks ago...
