Haltech Help???
Old May 19, 2001 | 01:53 AM
Styk33's Avatar
Haltech E6K
Arrow
Cosmo Donk should have this info. Why hasn't he posted here? If you have a good map in your car you should not need a BAC unless you are running an anti lag setup.
<A HREF="http://ricemobile.net/" TARGET=_blank> </A>
Jay
The Ricemobile
94 Base w/ never enough mods
87 Base w/ never enough miles
Old May 19, 2001 | 03:55 AM
MAZMAN's Avatar
i think the manuel says 30ms for the boost solenoid,but was told to run 33ms.tried both but had also trouble with the solenoid,could not get boost.
whats a BAC...my mind has just gone blank,i cant figure out what that is
Old May 21, 2001 | 10:40 AM
Cosmo Donk's Avatar
Queer
I haven't posted because I do not run a BAC. MikeL on this board runs one I think but as Jay said, they really are not necessary unless you run large electrical drains or you want a high cold idle to smooth things out like the stock thermowax.
Old May 21, 2001 | 11:10 AM
MikeL's Avatar
I do have one on the car. It is disabled on the PWM Options page.
The idle speed control is enabled on the output Options page. I have target rpm at 900. I have the physical idle screw set at 1000. The only time the BAC wakes up and makes noise is when I turn on the a/c. It drags rpm down to about 750 and then the BAC brings it up to 900.
I don't pretend to understand this. Maybe there's a better way to do it.
Mike
Old May 22, 2001 | 10:45 PM
Styk33's Avatar
Haltech E6K
Mike, now that you explained how you have yours setup, it makes sense now. If you read the instructions manual (if you have it) you will see that is says to 'disable' the PWM option for BAC if you are using it for idle speed control. That way it uses the settings in the 'input/output' page.
This all from reading the manual. I use mine for the ALS since the only elecrical draw on my car is my stereo
Jay
