Another Car wont start thread. i searched.
Old Nov 1, 2009 | 05:07 PM
Andrizzanizz's Avatar
I bought this car recently.
The only mechanical problem was the starter being bad so the car had to be jump started. I drove the car all the way from atlanta georgia to charleston south carolina and i had no problem. Once i get here i change out the starter with a new one. The car now cranks but wont start.
Im running an rtek and i ran the diagnostic on it and it didnt say anything was wrong.
last time i had this problem with my other tii it was the cas and the rtek said it was.
any suggestions?
car is a s4 tii with a s5 tii engine with a s4 front cover being ran off the s4 tii wiring harness and the rtek 2.1
Old Nov 1, 2009 | 05:13 PM
89fc3sgtu's Avatar
boosted fc
is it possible you flooded it
Old Nov 1, 2009 | 05:19 PM
i thought i did, but the p.o. told me that when the car floods just floor it because the rtek works like the s5 to where all you have to do is floor it.
and also i have a fuel cut off switch. i turned it off and i tried cranking the car. then i turned it on and it didnt do anything
Old Nov 1, 2009 | 06:10 PM
Black Knight RX7 FC3S's Avatar
Turbo power, activate!
all you did was change the starter??
You can try deflooding it, and put in oil through the spark plugs in each chamber and see if it starts from that.
Old Nov 1, 2009 | 06:34 PM
need RX7's Avatar
Listen to King Diamond.
Yeah I'd take the plugs out and crank it for a few seconds (I think you should still take out the EGI fuse for this, so you don't get sparking within the cloud of fuel that will come out) and add a little oil into the holes and try to start it again.
Old Nov 1, 2009 | 07:34 PM
alright thanks. i know how to deflooded it i just didnt think it was. but ill try it and see whats up.
Old Nov 2, 2009 | 10:08 AM
deflooding did nothing. the car still has the same problem.
Old Nov 2, 2009 | 11:25 AM
push started the car and nothing also.
Old Nov 2, 2009 | 02:26 PM
Amur_'s Avatar
Refined Valley Dude
- check for spark
- compression test
Old Nov 2, 2009 | 06:14 PM
Ryan123's Avatar
The Slowskys
Starter fluid? Alot of it?
Old Nov 3, 2009 | 12:26 AM
Is starter fluid good for a rotary?
Old Nov 3, 2009 | 10:12 AM
Amur_'s Avatar
Refined Valley Dude
Originally Posted by RotaryResurrection
I can't think of any reason [that it would be bad.] I mean, think about it. That's it's only
purpose in life, is to be sprayed into an engine to cause rapid
starting. Most of it is straight ether I believe, which is more
combustible than gas. When starting and with light throttle/revving
(trying to start and keep an engine running) there is no load on the
engine, and I see no real way that damage could occur. The worse thing
that'll happen is you could flood the engine with too much fluid, or you
could not spray enough and it'll lean out and stall. You can't cause
detonation or anything without significant load and intake temps,
neither of which are present under startup conditions.
Old Nov 3, 2009 | 10:17 AM
ahh. awesome man. thank you very much.
So where would be the best place to spray the starter fluid?
could i just spray it in where trailing plugs are?
Old Nov 4, 2009 | 08:32 PM
I took the ic off today (its a stock topmount) and unplugged the plug behind the alt. I then put the plug back and the ic. I cranked the car and it started after the second try. It then idled for around 7 minutes and then shut off and wont start again.
Old Nov 6, 2009 | 03:39 PM
anybody?
Old Nov 6, 2009 | 04:15 PM
DaBrkddy's Avatar
Smells like 2 stroke.
What are the four main things an engine needs? Fuel, air, and spark, and compression. Simple. Air is easy, so we can knock that out. If she ran good before, then chances are the problem is not compression. Is she getting fuel? Is the pump good? Injectors? Next thing is spark. Check for spark. Past that, if it's intermittent, then there has to be a problem with something that controls fuel or spark. Don't make this any harder than you have to.
Old Nov 6, 2009 | 04:53 PM
rtek got reset and now it starts but runs lke ****.
gtcd
30
Aug 19, 2015 02:44 AM
torky007
Aug 17, 2015 05:14 PM
ashleymiche
Introduce yourself
Aug 14, 2015 12:59 PM
