FD - Double checking fit before I order
Old Jul 4, 2009 | 01:58 PM
NeverDieEasy's Avatar
aka The BeasTT
Front - 18x9 +36 (Tire size: Undecided)
Rear - 18x10 +45 (Tire size: 275/45-18)
How well will these fit/look? All I'll have to do is roll the front fender slightly correct?
Thanks,
Nick
Old Jul 4, 2009 | 02:30 PM
wheels:
front will rub, ideally you'd want a 9 inch width +45. Need fender roll at a minimum.
rear are fine.
tires: recommend 245/35 front to minimize rubbing.
rear: you'll want 275/35 or 285/30, the size you have listed is way too tall and will look monster truck-ish.
Old Jul 4, 2009 | 04:28 PM
aka The BeasTT
Originally Posted by GoodfellaFD3S
wheels:
rear are fine.
It's primarily a street/strip car, so the extra side wall is due to the tire being a drag radial. Also forgot to mention the car is lowered on Tein S-Techs, does that change the front rubbing issues even if the lip is rolled flat?
Thanks
Old Jul 4, 2009 | 05:05 PM
Supastar Bruce's Avatar
No. More then likely you will be ok. And if you do happen to rub at all in the front, just roll your fenders out a little more. But I have 90% faith that with the lip rolled flat you will be just fine.
Old Jul 4, 2009 | 06:24 PM
gracer7-rx7's Avatar
needs more track time
wheels:
rear are fine.
+1
If you are primarily drag racing and want bigger sidewalls, it would make more sense to get 17" rims.
Old Jul 4, 2009 | 07:39 PM
aka The BeasTT
Excellent!!! Thanks guys!
Originally Posted by gracer7-rx7
+1
I agree. I'll eventually get a dedicated set of rims with slicks and skinnies, but right now funds are SUPER tight and I can get these 18's at a killer price
Old Jul 4, 2009 | 09:36 PM
Killer price won't be cheap enough if the fronts rub and you need to buy another pair of rims for the front.
Old Jul 5, 2009 | 12:10 AM
aka The BeasTT
Very true, I just might have to bite the bullet and get a Shine Burnout bumper and fenders then lol.
Old Jul 5, 2009 | 02:16 AM
Andrew.'s Avatar
The end of an era
You should really get some 18x12.5's and slap on 335's and pettit flares out back if you're going to be using it on that setup you have in your sig.
Old Jul 5, 2009 | 04:53 PM
aka The BeasTT
In due time
Old Jul 6, 2009 | 12:09 AM
Would be cheaper to buy something with an offset that works but its your money.
Old Jul 11, 2009 | 09:38 PM
DriftDreamzSS's Avatar
It will fit. I run 18x9+37 with 255/35's and had enough extra room that i added 5mm spacers too.
astrum
24
Nov 15, 2017 08:44 AM
driftfcbuckey
The Bad & Fugly Members
Dec 2, 2015 05:48 PM
rexone
The Bad & Fugly Businesses
Aug 23, 2015 06:24 AM
Turblown
Vendor Classifieds
Aug 18, 2015 10:01 PM
