Rtek 2.1 VR input not working?
Old Feb 11, 2008 | 09:16 PM
Silverfc88's Avatar
I got arournd to check to see why my VR analog input wasn't working anymore. I pulled the cover away from the ECU pulled the middle plug and turned the ignition switch on. I tested the ECU side of the plug with a multimeter where my wire connects to it and I was getting 2-3 volts and when the wideband was warmed up it read 5 volts.
I grabbed a wire with alligator clips on it and I reconnected my ATP input. Clicked atp in the ecu setup page and also clicked plx devices. Plugged the ECU back up turned the ecu back on and checked the voltage on the multimeter and the reading on the palm.
I was getting 13-14 afr's on the wideband for ATP and a steady 16 afr for VR. I connected them both at the same time just to test and my ATP is working, but not my VR. PLX devices where clicked for both inputs.
The VR input was working just a few days ago. Is it broken?
Old Feb 13, 2008 | 03:17 PM
Nick_d_TII's Avatar
Have you had any luck?
I just got my ecu installed last night, ran a few small logs, everthing seems to work, I'll be installing a PLX SM-AFR and WB O2 sensor this weekend and will be using the vr input... I'll let you know how it works out!
Old Feb 13, 2008 | 06:58 PM
Silverfc88's Avatar
No, I just left the VR input disconnected and reconnected my PLX back to the ATP.
Old Feb 13, 2008 | 07:23 PM
gxl90rx7's Avatar
destroy, rebuild, repeat
i havent had any problems with mine, its hooked up to my aem eugo wb. you did try deleting/reinstalling the pocketlogger sw?
Old Feb 13, 2008 | 08:02 PM
Silverfc88's Avatar
Yep, I did that when the timing tables went crazy on me.
When my tables crashed is when my VR input stopped working.
Old Feb 19, 2008 | 02:42 PM
Nick_d_TII's Avatar
Hmmm... I hooked up my plx over the weekend to the VR input and got the same thing?.... Started at like 15.88 or something and once it was all warmed up went to like 16 and stayed there flat...?
I'm going to look at it tonight or tomorrow?
I have only had one prob and the rx7 program had to reload settings from the ecu or something... lost my updated settings.. not that I had a lot...
I cannot confirm 100% if everthing is wired correctly, but I'm pretty sure...
Old Feb 28, 2008 | 08:57 AM
Silverfc88's Avatar
Do you have a N333 or N332 ECU?
Old Mar 9, 2008 | 03:31 PM
Nick_d_TII's Avatar
N332 I think... 87 TII..? Well anywho... Do I need to go through the Idle setup(Initial set coupler) before I can use the VR input... ???
Also, I put the capacitor, between the wire coming from the ecu (VR) and the WB output ground...?
Old Mar 9, 2008 | 07:48 PM
gxl90rx7's Avatar
whats the cap for?
Old Mar 9, 2008 | 08:52 PM
Nick_d_TII's Avatar
PLX instructions say "If you plan to integrate the SM-AFR with stand alone engine management systems, piggy back systems, data loggers, or any other devices that utilize the two analog outputs, noise filtering capacitors must be installed near the application. The included capacitors filter out unwanted electrical noise produced from your vehicle's ignition and other onboard systems. This provides added signal integrity for more accurate, reliable, and consistent measurements. Any 0.1uF 50V ceramic capacitor will work."
It has a diagram w/ the cap installed between the GND and the WB 0-5V linear analog output.
Old Mar 12, 2008 | 02:26 PM
Nick_d_TII's Avatar
Do I have to set up the IDLE before using the VR input? I don't understand how I can be reading volts w/ VR wire cut????
Has anyone used the VR input and had it work?
Old Mar 12, 2008 | 04:50 PM
gxl90rx7's Avatar
mine works, didnt do anything special. mines an 88
Old Mar 16, 2008 | 06:06 PM
Nick_d_TII's Avatar
Diagnosis
I looked into it further and took some pics and vid of what I saw...
Wire spliced correctly... its soldered.
The plx 0-5v linear output working.
RTEK logger shows voltage/afr for VR input w/ the plx output disconnected???
Here's my movie, but please ignore some of the stupid comments as I did not write them... And was just babbling in frustration...
Since I cannot select VR as an external reference, does that means its not loggable? or not usable as an input for some reason???
I'm going to wire it to the ATP and see if that works...
Old Mar 17, 2008 | 12:59 AM
turbo2ltr's Avatar
With the input hi-z (i.e. not connected to anything) the value of it is "undefined". Basically the test you ran is invalid as the reading can be anything if there is nothing connected to it. There is nothing "pulling" the sense circuitry to any particular value, so it's just "floating" around. What you are seeing is probably an input filtering capacitor slowly charging up.
Kinda like gravity. On earth you are always pulled to down until something stops you. You know you will always be at that point. Now imagine going into space...no gravity, so there is nothing to pull you in any particular direction so your location at any particular point can be anywhere.
I have heard of a report or two (not Rtek related in particular) about PLX's output being a little weak compared to some other WB02 systems..
I would measure the PLX output and while measuring it, connect it to the Rtek input and see if there is any change in the voltage when you make the connection.
Old Mar 17, 2008 | 08:35 AM
gxl90rx7's Avatar
or if you see it floating when disconnected, you could try grounding the VR input and see if it drops to zero on the rtek? that way you would know if it is rtek or not
Old Mar 17, 2008 | 10:56 AM
turbo2ltr's Avatar
Good suggestion.
I also suggest using the "voltage" preset in the WB setup for testing so the reading on the Rtek can be easily matched to the volt meter.
Old Mar 18, 2008 | 12:54 PM
Nick_d_TII's Avatar
Ok, Thanks guys, going to check it again today probably, and see what I get.
When I had the PLX hooked up initially, I pretty much saw the same thing on the PDA. (just slowly going up.. not AFR's/Voltages)
Thanks!
Old Mar 18, 2008 | 10:59 PM
Nick_d_TII's Avatar
Well.. hooked it up again, the exact same way as before. It works. It read a 12.5 - 13.6 AFR at idle. I think the PLX plug isn't getting a good connection to the ecu.
Initial test: The plx measured 5.0V on the meter.. hooked up to the RTEK ecu I showed 20.0 EGR.
Test after Install(hiding the box): Same as before... the 13.4 or whatever going up slowly.. jiggle the wire I got 18.9 or something (this was after a short idle time probably still had exhaust in the pipes).
Road testing tomorrow... But it worked just like it should! Yay!
Then step it up... need piping... Eeek!
Old Mar 20, 2008 | 10:45 AM
Nick_d_TII's Avatar
I took it out for a spin last night, everything seems to be working correctly.
Except I logged a 12.9 afr at 9.2psi... yikes, and my boost gauge reads higher than what the logger says? I've seen it edge to 15... but the most I've logged is 10 or so...?
Thanks!
Old Mar 21, 2008 | 11:21 AM
The Wankler's Avatar
FKITALL
What kind of boost gauge?
Old Mar 21, 2008 | 02:22 PM
gxl90rx7's Avatar
same problem i get.. above about 9-10 psi, the rtek starts reading about 2 psi lower than my boost gauge. I had the boost turned up to about 16 psi once, and the highest the log read was about 12.5 psi
Old Mar 22, 2008 | 10:21 PM
Nick_d_TII's Avatar
Autometer gauge.
My pressure sensor is tee'd into the line coming from the upper manifold to the BOV...
I'm going to tee it into the wastegate line... already has a nipple, I'll see if that makes a difference.
Going to richen it up a notch at +4k 9psi...
Old Mar 28, 2008 | 09:26 AM
gxl90rx7's Avatar
i swapped my boost references and it seemed to fix the problem?? the rtek and boost gauge read nearly the same now.
this is wiht the boost sensor is connected to the bottom port at the front of the UIM, my gauge and boost controller are connected to the port on the passenger side of the LIM
Old Apr 6, 2008 | 11:07 PM
Nick_d_TII's Avatar
Ok, I ran a log today and got a 'P2I lookup failed' and I can't see the VR on the log?
But everything else reads out? Anyone else have this prob?
Old Apr 7, 2008 | 09:47 AM
turbo2ltr's Avatar
Update to the latest version, build 4
www.digitaltuning.com/software/rtek.zip
