Rtek Rtek 7, i want one soooo bad!
Old May 25, 2008 | 01:17 PM
7fold's Avatar
so, for all of you with one, what controller are you using and what do you like and not like about them, im going to be getting the Rtek 2.0 and i would like to see what controlers most people have had success with...
pics of your setup would be cool too
Old May 26, 2008 | 06:59 PM
gxl90rx7's Avatar
destroy, rebuild, repeat
dontn get a T3, or any other that uses teh same connector. my old m100 worked perfect and was cheap ($30 on ebay a couple years back) but had no backlit display
Old May 27, 2008 | 02:10 AM
RotoriousRx7
i have a sony clie` and it works great but i think the cable has a loose conection and it looses connection. but great screen display.
no clue to what they cost since i bought mine from the icecreamman that was on this forum back in march of last year
Old May 28, 2008 | 11:26 AM
7fold's Avatar
anyone else????
Old May 28, 2008 | 04:05 PM
HHTurboVert's Avatar
CA
I originally used a Sony Clie S320, which worked fine until it I started getting NVRAM check sum errors after which the palm froze and the touch screen has never worked again. Now I use a Sony Clie S300(older model) that I bought for $25 shipped off ebay. It works great, but I wouldn't recommend using it if you have XP because you will have to download driver updates to make it work. Also the connector style on both these models is pretty weak.
The pluses are that they can be had cheap, they are common, the backlight display is nice and the battery life seems to be pretty good.
Old May 29, 2008 | 12:19 AM
boostedfc3s's Avatar
1.3 liter piston eater
I use a Palm E2. It's a little more expensive because it's not a real old model, but I love it. The cable is a nice tight connection, and the display is awesome.
Old May 31, 2008 | 03:17 PM
WingsofWar's Avatar
The Firestarter
Using Palm m515
WyomingTII
Rtek Forum
Oct 26, 2015 05:26 PM
Steelwheelz
6
Sep 15, 2015 03:22 PM
