Rtek 1.7 Flood Clear Issue
Old Aug 29, 2006 | 10:11 PM
winter39's Avatar
Got Rotors?
I have an Rtek 1.7 installed and am having some funny flood clear issues. When I try the flood clear by pushing the accelerator to the floor the car starts as if it is getting full fuel (high revs). I have had this on all 3 occasions that I have done the flood clear. Any reason this feature would not work correctly?
Thanks
Old Aug 30, 2006 | 01:59 AM
turbo2ltr's Avatar
You need to check your TPS sensor as per the factory service manual procedure and make sure the readings are in spec.
Old Sep 18, 2006 | 02:04 PM
winter39's Avatar
Got Rotors?
I put in a NEW TPS last nite and now it seems the flood clear works properly. I have a question now about hesitation. I will make a new thread for this. Thanks for all your help!
Jeff
SakeBomb Garage
SakeBomb Garage
9
May 11, 2020 10:04 AM
Jeff20B
73
Sep 16, 2018 07:16 PM
ZacMan
Sep 19, 2015 09:20 PM
