Rtek BNR stage 2 and a 1.7??
Old Mar 11, 2007 | 04:42 PM
younG_Gunner's Avatar
Re-Mama Mia!
I'm planning to finally beef up my motor this year. My rebuild is about finished with a mild street port. I have 550cc primaries, cleaned by RCengineering and new 720cc secondaries with a walbro 255 pump.
Ok, I appologize about this noob question, but I'm still learning about ems's. So my question is, If an rtek 2.0 would be able to support a BNR stage 2 Or would a 1.7 be all I would need?
Old Mar 12, 2007 | 01:16 AM
icecreaman's Avatar
2.0 FTW for sure. Not to sure about the 1.7... im not familiar with those
Old Mar 13, 2007 | 06:39 PM
Jturbo's Avatar
Go with the 2.0 The 1.7 compensates for 720cc injectors but runs them like stock and there is no way to adjust the fuel with out a fuel controller. The 1.7 is best for cars with a stock turbo pushing a bit more boost. If you are going with a bigger turbo like the BNR stage 2, the v2.0 will let you adjust the fuel and timing maps to your needs. This is a must have with a larger turbo and more boost.
Old Mar 23, 2007 | 02:32 AM
Re-Mama Mia!
Rtek 2.0
550 primaries and 720 secondaries
Walbro 255 Fuel pump
BNR stage 2 turbo upgrade
Corksport catback
And the Rtek will support ALL of this right? Just want to make sure before I forget something else.
Old Mar 23, 2007 | 07:41 AM
gxl90rx7's Avatar
destroy, rebuild, repeat
yes it should be fine. im running 750cc primaries, 1000cc secondaries with no problems. with a bnr stage 2 you may want to look at bigger injectors
as it is now, the timing control is limited above 100% load, which is at ~7 psi (it will keep the same timing values from 7 to 14psi), but a new revision is due out soon. A workaround is scaling your timing map back, so that your full boost timing value is 100 load (even though it will keep this value all the way down to 7psi)
and make sure you take a look at/adjust the timing map before boosting, its defaulted to 35 degrees advanced at full boost. I have mine trimmed and blended back to ~20 degrees at full boost (10 psi for me)
Old Mar 23, 2007 | 10:05 AM
Re-Mama Mia!
Talking
Would 720's all around be sufficient? I'm not out to make a monster. A decent 300 would make me content.
Old Apr 19, 2007 | 01:56 AM
netliv's Avatar
Yeah, I was wondering the same thing for my Rtek 2.0 setup and BNR stage 3.
Gxl90rx7 mentions bigger than 750s and 1000s for a stage 2. Really?
I'm only looking for 10 psi for now. Maybe upping it a little later.
Old Apr 19, 2007 | 08:52 AM
gxl90rx7's Avatar
Here is a decent fuel calc to estimate how much fuel you will need
http://www.rx7.com/cgi-local/2ndgencalc.cgi
If you look at the bnr website, it says stage 1 is capable of 300hp, stage 2 = 330, stage 3 = 350. I would use those numbers as a worse case scenario to estimate how much fuel you will need with that fuel calc above.. and remember rwhp=(flywheel hp)x0.85
and if you are looking for 720cc injectors, check out RC engineering 750cc, they make them low impedance, so no resistors needed
Old Apr 19, 2007 | 10:43 AM
gxl90rx7's Avatar
scratch that, i meant they are HIGH impedence, low imp you would need resistors
LongDuck
12
Oct 7, 2015 08:12 PM
matty
40
Oct 6, 2015 09:13 PM
