help QUIET my exhaust
Old Apr 21, 2006 | 09:33 PM
drft_180sx's Avatar
Ok, so i have the following mods on my car....
13B NA S4 Streetported, with the Exhaust Diffusers Ground out.
Racing Beat Headers (Not True Dual)
Racing Beat Presilencer
Corksport Stainless Steel Catback
I've already got my first ticket for the summer for excessive noise, and i can only imagine how many more i will get if i don't quiet her down...
Please help me with any suggestions that you might have...Thanks in advance.
My thoughts: I was thinking that maybe where the front section of the catback is, I can cut and weld in a small walker (joe schmo) muffler..any thoughts?
Jahan
PS> Pic to help us all visualize...the prize! ok that was just corny.....
File Type: bmp
Old Apr 21, 2006 | 09:42 PM
Green_Streak's Avatar
slower than granny
a corksport is going to be loud on any N/A, and probally even moreso with tickets and such. i used to have almost the same setup, i had the downpipe instead of the header, the presilenser, and a corksport. i ended up ditching it and getting a set of RB mufflers and a y-pipe
Old Apr 21, 2006 | 09:51 PM
drft_180sx's Avatar
I wish i could tell you how much I would like to get the RB catback, but because of the great big difference in price of the RB and CS, I had to settle with the CS....sigh. Anyone have any advice?
Old Apr 21, 2006 | 10:00 PM
eddierotary's Avatar
back with rotaries
put a dynomax bullet muffler betwen the presilencer and the muffler and it should quiet it down alot. plus is small and it uses SS packing so it wont burn
Old Apr 21, 2006 | 10:22 PM
drft_180sx's Avatar
I was considering the Bullet type mufflers, and i was definetely worried about the fiberglassed packed ones...
But, will the bullet significantly reduce the noise you think? Any one have any experience with the bullet?
Thanks again...Jahan
Old Apr 22, 2006 | 12:35 AM
Drivarotor's Avatar
I have a Rotary Performance catback setup (not installed yet) and I have been re-assured that it is quieter than a Corksport, but still maintains a deep throaty tone. Much more affordable than the RB catback. All in all, I have the RB merged header, a Bonez high flow cat, and the RP catback and had it all delivered as 1 order for $904. Installation and pics will be coming in the next month or so. I have to match port the intake manifolds and ditch the exhaust diffusers.
Old Apr 22, 2006 | 12:59 AM
emac's Avatar
put a borla xr-1 in it
Old Apr 22, 2006 | 01:24 AM
kungfuroy's Avatar
Chicken Adobo
or you can try that CS catback plug for $27 to see if it quiets things down. try cheapest first
Old Apr 22, 2006 | 02:07 AM
Black91n/a's Avatar
Maybe you could put a Super Trapp muffler on the end of the whole thing.
Old Apr 22, 2006 | 03:13 AM
slower than granny
actually i only ended up laying out $359 for the RB catback. the math? $289 for the corksport, $270 for a pair of RB mufflers, and a friend gave me $200 + the old Y-pipe off his 87 TII, so net i only spent $359. probally a good thing too cause it was starting to get old for me...
Old Apr 22, 2006 | 03:38 AM
KeloidJonesJr.'s Avatar
strictly business
Ditch that system, go back to stock and get the N1's. They have silencer.s
Old Apr 22, 2006 | 04:36 AM
Jager's Avatar
Tear you apart
It does help but makes it sound raspy. Also it doesn't secure up properly and eventually shakes loose. They were cool about giving me a new one but it rattled too.
Not worth the time .
Old Apr 22, 2006 | 04:38 AM
Jager's Avatar
Tear you apart
Um no.
It's a very heavy exhaust for what it is (look at its construction, have you seen it off the car?)
Another note, a Borla XR-1 works well for the Corksport turboback exhaust, the problem is the entire lack of a muffler that the system has. You want more for an NA in the muffling department. I heard a XR-1 +RB presilencer (the big ones) and it barely did anything.
I suggest the Borla cat-back, it makes good power and weighs 11lbs more then the Corksport exhaust.
Old Apr 22, 2006 | 05:53 AM
RevUp13b's Avatar
zZzZzZzZzZz..............
I had the exact same setup (RB header, RB presilencer, CS catback) it was so loud i juss put back on the cats, lol... i would recomend another catback, the cs one doe really nothing to muffle the noise.
Old Apr 22, 2006 | 08:12 AM
jgrts20's Avatar
Who are you?
buy a resinator for your midpipe and get the resinator exhaust tips. Thats what I did, works fine.
Old Apr 22, 2006 | 08:30 AM
JJohnston's Avatar
do resinator exhaust tips work well, or barely at all?
Old Apr 22, 2006 | 09:38 AM
FD3S_wanted's Avatar
$270 for a pair of brand new RB mufflers? Or used one?
Old Apr 22, 2006 | 09:51 AM
Sideways7's Avatar
what about magnaflow mufflers?
Old Apr 22, 2006 | 09:55 AM
jon england's Avatar
i have seen a flap system on the market with a lever that partially blocks the exhaust and reduces both emmisions and noise, these are used on some cars from factory including bmw( in the uk anyway, although on bmw it is controlled by the ecu) the idea is that you fit a round flap slightly smaller than the bore of the exhaust in the pipe near a joint that you can manually open and close to yor own reqiurements. the idea is that at idle and lower revs you can shut of the exhaust, this will reduce the gasses comming out of the system and have the combined affect of helping with emmisions at mot and when tootaling around town keep the noise down.
Old Apr 22, 2006 | 01:39 PM
walken's Avatar
Registered Loser
Header wrap and a muffler silencer might drop your exhaust note a few decibels. You could take it to a local shop and have them make you a custom exhaust with a couple inline dynomax/magnaflows. Then sell your CS catback to recover some of the loss.
Old Apr 22, 2006 | 05:45 PM
arghx's Avatar
rotorhead
You have to change your catback dude if you want to keep the header. I was in a very similar situation. I had RB collected header, RB presilencer, and Apexi N1 duals when I bought the car. The car was sooooooo ******* loud... it gave me headaches. It resonated so bad I was getting a back message at highway speeds.
I tried a couple things to quiet it down and still keep the catback. First I replaced the RB presilencer with a cat. That helped significantly. It didn't resonate so bad on the highway, but it still droned really bad. I drove the car like that for maybe 6 months, but finally I was dating this girl who really got bothered by the noise. So I went to muffler shop and had them install a restrictive resonator type of thing, the kind that constricts flow down to like a 1.25" bend inside. It quieted the car down a lot. It pretty much did the trick--except it killed my power.
I drove the car like that for maybe two months. Then the girl and I broke up and I realized that I wanted my power back--I missed the kick in the *** I used to get up top. Finally I just said **** it and bought a used RB 2.5" catback. I changed the catback and replaced the cat and resonator with a straight midpipe.
Suddenly the car got all its juice back. I went back on the dyno and it turns out that I had lost 25(!) horsepower from all that bullshit I had put in trying to quiet down the N1's, and the RB catback was actually quieter and smoother AND made more power.
Lesson learned: if you want to keep a header, don't use a really loud catback. I'd say dual N1's are equivalent to a corksport in loudness. Sell your catback and get something else.
Old Apr 23, 2006 | 01:33 PM
slower than granny
$270 for a set of used ones. i really don't see the problem with used ones as new ones will be used as soon as you put them on anyway. only problem i see with used ones is they aren't always avilable
Old Apr 23, 2006 | 02:55 PM
D'Movement's Avatar
Designed by ORC
Why don't you try an Apexi ECV unit, http://www.apexi-usa.com/product_exh...=251&pageNum=1
Old Apr 23, 2006 | 05:02 PM
dori91borofc's Avatar
do you have experience with the ECV??? ive been looking for reviews but i cant find anything.. does it actually make a big difference on sound??
Old Apr 23, 2006 | 05:30 PM
Noel Caraballo's Avatar
use a borla xr1, trust me i had the same setup , the borla did way better than racing beats presilencer, check it out on summit racing
Ian_D
Sep 6, 2015 10:38 PM
doritoloco
Sep 5, 2015 12:41 PM
FührerTüner
General Rotary Tech Support
Sep 4, 2015 01:41 PM
