Exhaust question?
Old Nov 9, 2005 | 08:29 AM
bigdaddyp's Avatar
Exhaust question?
I have a question about exhaust. I heard someone in the kill section say "about 90 MPH where the exhaust restriction takes my top end power away". Could this be my problem? When I get on it in mine, it pulls pretty hard and runs thru 80 easy, but then around 90 or 100 it doesnt seem to be gaining as fast as it should, it takes quiet some time to get to 100 from 90.
Old Nov 9, 2005 | 08:31 AM
J-Rat's Avatar
Alcohol Fueled!
Model? Mods?
Old Nov 9, 2005 | 08:36 AM
tIIsleeper's Avatar
pp
If its an na itll take a bit to get up there, but my friends hits 120 easily. If its a turbo then you have a problem.
Old Nov 9, 2005 | 09:34 AM
bigdaddyp's Avatar
it is an 86 GXL, it is bone stock. Any way cats could cause this probleM?
Old Nov 9, 2005 | 09:41 AM
Anti-Rice-Cannon's Avatar
My Car Makes Me Smile
Check to make sure 5th and 6th ports are opening up. My wern't and it was ver hard to go over 110. a 5 cent, ground wire gave me tons of power.
Old Nov 9, 2005 | 09:46 AM
bigdaddyp's Avatar
lol how can i check them? I can hear a whistle in 1st and 2nd really good around 3500
does this mean they are opening for sure, and any way they coudl not be opening in my higher gears? Cause i dont hear it in 3rd 4th or 5th
Old Nov 9, 2005 | 09:47 AM
J-Rat's Avatar
Alcohol Fueled!
Yes, cats could cause this.,.. OR your 6-ports arent opening.. OR your car needs a tune up.
Checking the 6-ports is in the FAQ.
Rat
Old Nov 9, 2005 | 08:17 PM
JoshRX7's Avatar
Or it could just be form drag (wind resistance) from the relative wind (car moving through the air). If you double your speed... say 50 to 100... your drag doesn't double -- it increases four-fold. So, just something to consider. The way to battle drag (a rearward acting force component) is to increase your forward acting force component (read: more power/torque). So, assuming your car is up to par, you'll have to increase power/torque to rip through the wind like you're wanting.
And just a sidenote... don't know what gear you're using while winding through 100... try 4th; not 5th. But, drive safe. And always remember speed rating and condition of your tires when driving at those kinds of speeds.
Josh
Skeese
Adaptronic Engine Mgmt - AUS
65
Mar 28, 2017 03:30 PM
msilvia
28
Apr 14, 2016 12:58 PM
12abridgeport
Aug 17, 2015 06:28 PM
