Rtek rtek questions about Map based timing mode
Old Sep 29, 2008 | 05:02 PM
socalrx7racer's Avatar
okay, i have the 1.5 version already installed. i bought an 87 tII and the previous owner had this mod done. i'm wondering 2 things.first if i switch to map mode am i then able to get rid of my maf and just run a map sensor(also what map sensor would i have to use to do this) and second, it says there is no preset timing map when i get it. am i able to just copy someone's or is mapping it out a pain in the ***.
basically i'm wondering if it would be worth the 300 dollars to uprade to stage 2 to get the map mode. or should i just upgrade to the stage 1.8 and use my MAF. or should i just get a fully programmable.
my goal is 400hp+/- 50 hp. so far the plan is to take the motor out and get street ported and the exhaust ported. not sure what injectors probably 750/1000 i have a walboro 255 i haven't picked a turbo up yet but i am in the middle of sourcing one and its gunna have a custom upper intake manifold.
also i'm wondering if i would need to even get rid of the maf to make that power but i think thats a Q for the 2nd gen tech section
Old Sep 29, 2008 | 05:08 PM
Wizz's Avatar
As of now there is no MAF delete available at all. And to change/tune anything (timing or fuel, etc.) you will need at least 2.x.
Old Sep 29, 2008 | 06:03 PM
do you think i'd be able to make my desired horespower using 2.0 (or even 1.8)? its starting to sound like upgrading my rtek isn't gunna be enough control for the setup i'm using.
Old Sep 30, 2008 | 12:04 AM
rogrx7's Avatar
Turbovert done.
You can probably do 350...but that depends on many variables.
400hp and reliability does not go hand and hand.
To reach 400hp you need HEAVY mods and full blown ECU (Haltech,Microtech)
If your looking for a cheap solution to 400hp..its not going to happen.
smikels
Rtek Forum
May 12, 2016 12:34 AM
stickmantijuana
Engine Management Forum
11
Nov 9, 2015 01:15 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
stickmantijuana
20B Forum
Aug 19, 2015 01:47 PM
baconflavored
SE RX-7 Forum
Aug 12, 2015 12:07 AM
