Rtek how do you like it
Old May 12, 2008 | 03:56 PM
fcforlife's Avatar
rotary tech
how do you like it
hey im new to this part of the forum. im looking into getting a ecu. i was thinking about the different options in brands and wanted to know how u guys like your rtek7 stage 2. i have a s4 na that i wanted to get one for.
Old May 13, 2008 | 09:04 PM
WingsofWar's Avatar
The Firestarter
I love it, i cant wait for updates tho
Old May 15, 2008 | 01:20 AM
fcforlife's Avatar
rotary tech
updates?
Old May 15, 2008 | 08:33 AM
gxl90rx7's Avatar
destroy, rebuild, repeat
afm removal is what im waiting for. Other than that, the 2.1 is working out really well. I recently swapped my 1000cc secondaries for 1600's, and was able to lean them out without much hassle. After tweaking the timing tables, i get 24mpg hwy now. cant complain
Old May 15, 2008 | 01:27 PM
WingsofWar's Avatar
The Firestarter
you get 24mpg?! gah! your gona help me out a little then with my timing, just keep hitting a snag here and there
Old May 16, 2008 | 11:32 AM
Roen's Avatar
The Silent but Deadly Mod
I get a little more than 24 mpg with my Rtek NA?
Old May 16, 2008 | 01:16 PM
10thslydur's Avatar
thats so awesome i thinking about runnin the 2.1 with a bnr 4 with 720 pri's 1600 sec's
with i new rebuilt sp s4 what do you think of poweer gains or range i can look for, also this will be my first ecu upgrade is it fairly easy to learn the rtek system
Old May 16, 2008 | 05:43 PM
gxl90rx7's Avatar
I would say its the easiest to learn of all the aftermarket ecu options, especially since its based on the stock map. You dont have to create one from scratch. however, that can be a disadvantage to experienced tuners, because you are stuck with tuning from the stock map, not a fresh start. But it is a good setup to learn on.
ive found tuning 1600s is a little tricky with the new load based staging, since the secondaries dont turn on at a set PSI. In low gears, it seems to happen at around 5psi.. i still have to do some testing in 4th and 5th to see if it will stage at lower boost. it also helps to use the 550/720 preset
Old May 20, 2008 | 09:26 PM
fcforlife's Avatar
rotary tech
when should the afm removal be available and if i bought and rtek how hard is it to get the update?
Old May 20, 2008 | 10:15 PM
WingsofWar's Avatar
The Firestarter
ahh when should the afm removal be available...the mother load of all rtek questions...lol
