Rtek the Rtek7 S4 NA Stage 2 ECU
Old Apr 25, 2008 | 08:18 AM
Cpt.Zanzibar's Avatar
Rotary Rocket
http://www.pocketlogger.com/index.ph...age=2&ecu=S4NA
anybody have this done? i have been looking into getting one but im not sure. what are your guys experiences? worht the cashola?
Old Apr 25, 2008 | 08:51 AM
AbortRetryFail's Avatar
Trunks are for corpses.
I've got one. It's sweet.
I've managed to get a bit more pull in the midrange by tweaking the fuel maps. Nothing extensive until i get a wideband.
The install is a breeze, just plug it in and it's done. It makes setting the idle speed and mixture easier too. (It's done thru software, there's a little 3 page wizard for it.)
The guys over at DigitalTuning are pretty responsive with support too.
Word of wisdom: Don't use a Palm TX - the serial ports on them SUCK and they have all kinds of connection issues.
Just pick up a cheap palm m1xx or m5xx off ebay or something.
Old Apr 28, 2008 | 07:34 AM
Rotary Rocket
thanks for the info.
one question, how did you install it yourself? the site dosnt give an option to buy the chip itself.
Old Apr 28, 2008 | 09:03 AM
*TOUCH*'s Avatar
Project P --- Pedospeed
i think he meant setting it up, not installing it. i could be wrong but i think you have to send your ecu to them and they send it back with a chip in it. you just plug your ecu back up and go from there setting and tweaking as you like.
Old Apr 28, 2008 | 12:46 PM
Digi7ech's Avatar
I break Diff mounts
The stage 2 is not just a flashed chip. It's a daughter board and actual software.
Old May 10, 2008 | 03:26 AM
7fold's Avatar
what kind of interface do you use with the chip? like what do you use to control everything?
Old May 10, 2008 | 10:02 AM
*TOUCH*'s Avatar
palm pilot
Old May 10, 2008 | 12:27 PM
Silverfc88's Avatar
I remember a thread where someone tweaked the fuel maps and was able to gain alot up top.
Edit: Nevermind, its the sticky up top. It was an S5. https://www.rx7club.com/showthread.p...&highlight=top
Old May 12, 2008 | 05:06 AM
fcforlife's Avatar
rotary tech
can u run a laptop or do you need a palm pilot? what os can u run? whats the turn around time on sending out the ecu?
Old May 12, 2008 | 05:11 AM
fcforlife's Avatar
rotary tech
never mind i read the faq haha
