Rtek has anybody logged more than 11psi?
Old Feb 25, 2008 | 09:10 PM
gxl90rx7's Avatar
destroy, rebuild, repeat
i finally got an ebc installed, and turned the boost up to about 13 psi.. the problem is in the logs, it only goes up to about 11psi. anybody get this problem? does the stock sensor just loose accuracy that high?
Old Feb 26, 2008 | 01:36 AM
AUGieDogie's Avatar
well on my stage 2.0, i loged 12.5 quite a bit. The stock pressure sensor is pretty good from what i've read. Yours might be reading wrong, or your boost controllers settings might not be correct.
Old Feb 26, 2008 | 06:09 PM
RotoriousRx7
i have logged 15.8 psi last year at the drag strip? it was that high for like 200 rpms... it was the finals and i had to turn it up a few psi to smoke this subie sti with bunch of goodies but besides that i had no problem logging more than 11 psi
Old Feb 26, 2008 | 07:01 PM
gxl90rx7's Avatar
ok thanks, ill have another look at it. maybe my restrictor pill is too small orsomething
Old Feb 27, 2008 | 01:02 PM
RotoriousRx7
well i dont have the restrictor pill in mine so maybe that has something to do with it... but i cant remember what its does (boost restrictor pill?)
Old Feb 28, 2008 | 12:02 PM
The Wankler's Avatar
FKITALL
With 2.0 I was loggin up to 14 psi.
Old Apr 12, 2008 | 02:42 PM
tIIsleeper's Avatar
pp
ive logged at least 15 with the 2.0
Logan Reinisch
General Rotary Tech Support
44
Sep 17, 2018 12:20 PM
eddierotary
Microtech
Sep 26, 2015 06:49 PM
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
AXA
Sep 5, 2015 10:06 AM
