Rtek Rtek 2.0 and t04s
Old Jul 23, 2006 | 08:25 PM
nigorx7's Avatar
Rtek 2.0 and t04s
I would like to know if the RTEK 2.0 would be able to tolirate my modification?
MY set up:Turbo hybrid to4s
external wastegate
fmic
3" straight pipe exhaust
bov
4x 720cc injector
cold air intake
walbro fuel pump
Centerforce dual friction clutch
I would like to boost up 12psi,Is it possible?
Old Jul 24, 2006 | 07:00 AM
X-JaVeN-X's Avatar
Drive.
i don't see why it couldn'tt
Old Jul 26, 2006 | 02:22 AM
Henrik's Avatar
Should be fine. You should at least tune with as wideband to ensure that your not
leaning out. Keep an eye on the AFM sensor and max duty cycles (on the log screen)
during tuning to make sure you not maxing either. You'll probably want to pull a bit of
timing as well.
-Henrik
Old Aug 2, 2006 | 11:38 AM
sonick117x's Avatar
the crowned prince
dont flame me.. but what is controlling the boost to 12 psi?
Old Aug 2, 2006 | 07:37 PM
nigorx7's Avatar
Turbosmart manual boost controler
Old Aug 3, 2006 | 12:14 PM
sonick117x's Avatar
the crowned prince
thank you.. that was probably the most straightforward answer i could ask for
WyomingTII
Rtek Forum
Oct 26, 2015 05:26 PM
James Knox
Introduce yourself
Oct 22, 2015 05:08 PM
lnlreaper
Sep 27, 2015 09:59 AM
