car wont start
Old Oct 3, 2005 | 05:19 PM
88rx-7's Avatar
car wont start
I have a 88 GXL and it was carbon locked but i just got it free and put everything back together. I replaced the plugs, air filter, oil filter, fuel filter...the works. when i try to start it, it hesitates then winds up to 2000rpm then dies. any ideas??? please help!!!
Old Oct 3, 2005 | 06:52 PM
BuffDaddy915's Avatar
Tha ladies man
Check TPS to see if its adjusted correctly.
Old Oct 3, 2005 | 06:57 PM
Innovation's Avatar
I'm still a rookie but if that doesn't work check the fuel filter and pump. Mine was clogged and had the same symptoms. Also I had the injectors cleaned and flow tested. Sorry just saw you changed the fuel filter but I was refering to the sock in the tank.
Old Oct 3, 2005 | 07:00 PM
Tha ladies man
Ya, he mentioned he replaced the fule filter already so thats ruled out.
Might want to look at your AFM too.
Old Oct 5, 2005 | 12:44 PM
88rx-7's Avatar
Ill check the TPS tonight, I still gotta check the fuel pump. Is it possible that its a compression problem? blown apex or warped housing maybe???
Kyo
6
Apr 13, 2019 09:24 AM
gtcd
30
Aug 19, 2015 02:44 AM
torky007
Aug 17, 2015 05:14 PM
ashleymiche
Introduce yourself
Aug 14, 2015 12:59 PM
