Aluminum belly pan
Old Jul 2, 2009 | 06:20 PM
JxT's Avatar
JxT
Aluminum belly pan
Does anyone happen to know the dimensions of the bolts? Somehow they disappeared from my shelf so I need to get a set now, thanks.
Old Jul 2, 2009 | 06:41 PM
NeCr0mStR's Avatar
I just wanna hump my car.
6mm with fine thread I think.
if thats what you mean
Old Jul 2, 2009 | 07:21 PM
JxT's Avatar
JxT
Yeah that's what I meant. What about the length of it though or doesn't matter?
Old Jul 2, 2009 | 07:24 PM
NeCr0mStR's Avatar
Doesn't matter for the most part, but go with 1.5 inches with a good sized washer for it.
and, do you have an aluminum underbelly pan?
Old Jul 2, 2009 | 07:27 PM
JxT's Avatar
JxT
Yeah I do. I took it off awhile ago to find some leaks and my bolts either got swiped or thrown in the trash, no idea. Leaks finally fixed so I wanted to put it back on.
Old Jul 2, 2009 | 07:33 PM
NeCr0mStR's Avatar
Where did you get it from and how much?
Old Jul 2, 2009 | 07:41 PM
13bturbofc's Avatar
mmm doritos
1.5 inches is way to long..the factory ones are like half inch...but you could get away with inch. 1.5 is pushing it
Old Jul 2, 2009 | 07:53 PM
NeCr0mStR's Avatar
That's why I said with nice washers. I use 2 of them and that's a .25 inch taken off and some of the bolts almost fall out when I take them off with 1" bolts in mine. His pan is aluminum and will be thicker than the plastic one and with a good washer it will take another 1/8 inch off the bolt. I know the bolts I use at an inch are hard to got started with a socket because they sink down into the socket.
Old Jul 2, 2009 | 08:23 PM
JxT's Avatar
JxT
Just to make sure, I was referring to the aluminum plate that covers the oil pan that was part of the aero kit. Since you mentioned something about plastic I got a little confused.
Old Jul 2, 2009 | 09:00 PM
EvilWankel's Avatar
Knucklehead
Those are real hard to find. Most are made of plastic. Don't sell it til you're flat broke.
Old Jul 2, 2009 | 09:36 PM
JxT's Avatar
JxT
Ah, I've never seen that thing in plastic before. So anyone else wanna chime in on the size and length of the bolt?
Old Jul 3, 2009 | 09:15 AM
Aaron Cake's Avatar
Engine, Not Motor
Seriously, they are bolts. M6, about an inch long. It's not critical. You could probably use 2 or three inch bolts in many of the holes. These bolts are used all over the car, hundreds of them.
Old Jul 3, 2009 | 10:26 PM
NeCr0mStR's Avatar
That's what I'm screaming.
LongDuck
12
Oct 7, 2015 08:12 PM
